      Jun 2008
      Alaska
      Pedal layout information
      been searching the threads but can't find any info on laying out my pedals for my ls2 conversion in 66 lemans, it was originally an auto car and I'm going manual 6 speed, anything on after market or using the setup i puled from my 04 gto, i have the drive by wire pedal, brake and clutch and master cylinder assembly. or should I use something else for ease of installation thanks
      Jan 2014
      Seattle WA
      Not overly complicated. I used a clutch/brake pedal assembly from a donor and will use the pedal assembly out of the donor truck my LQ4 came out of. Haven't gotten to the gas pedal yet, but its coming quickly as I tie up the interior. Should be a post on the hydraulic clutch assembly on my blog. Link in my sig. 67 El Camino, so the same basic under dash as yours.
      1967 El Camino 408ci LSx....and the build begins!
      1967 Turbocharged 408ci LSx Chevelle - 1012 rwhp, 959 rwtq 67 Chevelle
      2009 Supercharged Silverado - On the Dyno
      Jun 2008
      Alaska
      Thanks will check it out
