    Results 1 to 12 of 12
    Thread: Viper T56
      Nov 2012
      Viper T56
      Hey guys, im sure theres a thread out there somewhere about this but i couldnt find one with everything i needed. i can get a good deal on a viper t56 to go behind my 78 firebird with a first gen 350 in it. the questions i had are:
      what are the differences in shifter location between that and the trans am t56?
      is there any difference in torque ratings between the two?
      does the viper t56 make it any harder to swap into my application than a t/a t56?
      are the gaer ratios the same?
      can i still get an adapter plate and use my stock clutch linkage?
      and are there any problems ill run into with the # of splines (are they different than the t/a t56)?
      thanks guys, looking at buying it today if there are no problems
      Nov 2011
      charlotte nc
      from what i've noticed, finding a viper t56 is next to impossible. It does have very strong syncros, but it's not hard to upgrade a standard t56 to that level. Why are you looking at the viper box in particular?
      JohnnyCichowski.com <- ls1 miata build, race results, product reviews, yada yada yada...
      Walla Walla, WA
      Quote Originally Posted by 78 Bird View Post
      Viper is a bit more forward than the LS1 style T56
      The Viper is stronger than an LS1 T56
      No, other than that the rear mount is farther from the centerline of the output shaft (lower) by about 1.5" or so, so a cross member designed for an LS1 T56 would need to be modified
      Yes, the same as a 2.66:1 LS1 T56
      Yes
      Viper output shaft is different than LS1 T56 output shaft, but yokes are readily available.
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Nov 2012
      Quote Originally Posted by nine lives johnny View Post
      im really looking for any t56 but that one showed up on craigslist for a fair price so i thought id see if its worth it only 30k on it too. he is asking 1500 obo
      Nov 2012
      Quote Originally Posted by Mkelcy View Post
      Yes
      Thanks so much, very helpful, looks like I'm going to try and make a deal on this one
      Walla Walla, WA
      One other thing - The Viper input shaft is longer than that of an LS1 T56 and the portion that goes into the pilot bushing is thicker. The length works with the 1/2" thick adapter plate, but you'll need to find a pilot bushing that works (someone may make one) or have a machinist (don't do this on your home drill press) bore out a standard Chevy pilot pushing.
      Nov 2012
      Perfect, I know a guy who can get that done, thanks again for the info!
      Nov 2012
      Update on the transmission: I stopped down to look at it today and it was very clean, with paperwork proving that it came from a viper shop near us and it included the yoke and the shifter, clicked into all gears and seemed to be fine after inspection so I ended up buying it. talked him down to $1,350, good deal? now one quick question, I am planning on running the adapter plate and my stock bellhousing, when looking for clutches, am I looking for a clutch that would go on a viper that the tranny came from or does it have to be something different, only reason I ask is because I am using the stock bellhousing and the manual clutch linkage and I wasn't sure what clutch to get since I believe the viper would've had a hydraulic clutch. if someone could just clear that up for me so I know what I'm looking for that'd be great!
      Walla Walla, WA
      If you're happy with the clutch you have now, all you need to do is get a clutch disk for a 26 spline 1.125" diameter input shaft and swap it in.
      Nov 2012
      Ok, I don't really want to keep my clutch since it is I believe a stock replacement from all the way back when my car had a 305 in it. but from what it sounds like, all I'll need to do is get a clutch kit that has a disk for 26 spline 1.125" di. input shaft and just make sure it matches up with my flywheel and I'm good to go?
      Walla Walla, WA
      That should do it.
      Nov 2012
      That should do it.
      perfect! you've been a huge help! hopefully everything else in the swap will go smoothly.
    Tags for this Thread
