      Nov 2013
      near Charlotte, NC
      FAST Traction Control on Autocross Course??
      I'm fighting traction problems coming out of a turn on my 84 Grand National. Anyone tried FAST's traction control on Pro-touring course?
      conrad
      Original owner '84 Grand National. CAS V1 (big) front-mount intercooler, Comp roller hyd cam, Champion Al intake/heads, T66 turbo, 3.5" custom cat-back exhaust, RideTech TruTurn front & DSE rear swaybars/ctrl arms, Ridetech 3-way coilovers, Baer 6P 14/13. FAST w/TouchScreen & GM Flex Fuel sensor, 120 lb injectors, Ricks SS tank, Aeromotive Eliminator pump.
      May 2013
      qld Australia
      Country Flag: Australia
      wouldn't traction control severely affect the performance and lower your track times? maybe some suspension tuning or stickier tires?
      Mopar or no Car
      Your either with us or Behind us
      Lawrenceburg, TN
      Im just guessing on your car set up here but if your triples are tuned close to a good base for your car ....then disconnect the rear sway bar and see if its better,,,remember the rear sway bar is a tuning aid not a set in stone item to run all the time at every track...my rear bar has 3 settings and I added extra on the upper mounting points and with 3 lower adjustments and 3 upper adjustments(thats about 18 options for me)and with that I have even found a track that I still disconnect on for my car
