    Page 68 of 80 FirstFirst ... 18 58 63 64 65 66 67 68 69 70 71 72 73 78 ... LastLast
    Results 1,341 to 1,360 of 1589
    1. #1341
      Apr 2014
      Good day to be stuck in the shop with a snow storm. Started to make the custom X pipe to fit between the trans crossmember and driveshaft loop.
      Pat
    2. #1342
      Feb 2014
      Just spectacular.
    3. #1343
      It's great having you around here Pat, Just by checking your build you must have solved a lot of problems for a bunch of people.It looks like it's going to work out well.
    4. #1344
      Apr 2014
      Thank you sir! I appreciate you checking in on this very slow build. A lot of very cool cars on this forum and I’ve learned my fair share from quite a few different builds.
      Pat
    5. #1345
      Apr 2014
      Slowly cutting, sanding and fitting the exhaust puzzle piece by piece;-)
      Pat
    6. #1346
      I'm lovin it Pat, it looks like a nice fit.
    7. #1347
      Sep 2013
      sw Kansas
      Looking good. I'm surprised you didn't use a color matched strap to hold them.
    8. #1348
      Apr 2014
      Slowly working my way aft piece by piece. I’m trying to keep the exhaust as close to the floor as to not see any of it hanging down from a side profile. Using welded on exhaust flanges certainly clean up the appearance.
      Pat
    9. #1349
      It's looking good.
    10. #1350
      May 2017
      Los Angeles, CA
      Weld flash
      Hi Pat,
      Two questions, 1) How are you protecting the undercarriage from weld-flash as you tac the exhaust together? And,
      2) What are the white & blue elastic straps holding the exhaust pipes to the cross-member & driveshaft?
      Thank you,
      Brian
    11. #1351
      Apr 2014
      Quote Originally Posted by GrayRaceCat View Post
      Hi Pat,
      Thank you,
      Brian
      Brian,
      1. I just slide a piece of cardboard between the pipe and the floor.
      2. The elastic strap holding the center of the exhaust up is nothing more than a double bungee cord that has a blue ball on either end instead of a hook.
      Pat
    12. #1352
      May 2010
      Phoenix AZ
      1968 Charger and 68 pages of wonderful! Supposed to be working on my own project but started reading and did not stop until I made it through all 68 pages!
      Incredible build. I owned a very very nice '68 Charger RT many years ago. Always wanted another. Had a 70 Superbird a few years back but the '68 Charger is high on list.
    13. #1353
      Apr 2014
      Quote Originally Posted by ProjectSideOiler View Post
      Wow 68 pages over 5 years, crazy! I hope It doesn’t take another 68 pages to finish this project;-) Thank you!
      Pat
    14. #1354
      Sep 2013
      sw Kansas
      I'm in complete agreement on the exhaust hanging down statement. Then it looks like an afterthought. Hiding 3" exhaust isn't easy.
    15. #1355
      Aug 2013
      Shelton WA
      Damn. fantastic build.
    16. #1356
      Apr 2014
      Quote Originally Posted by SPLATT71MC View Post
      Thank you sir!
      - - - Updated - - -
      With the exhaust tack welded in place forward of the mufflers, I have started working on the tail pipes. Unfortunately with the inboard mounted 4 link I have to modify the TTI tail pipes to fit.
      Pat
    17. #1357
      Nice job Pat.
    18. #1358
      Sep 2013
      sw Kansas
      I thought I heard Rum Rum for a moment. Good progress. Exhaust wouldn't be bad if the car was on it's side or upside down.
    19. #1359
      Aug 2008
      jacksonville,fl
      One side of your exhaust looks about 1/64" off from the other. Better fix it before you loose sleep.
      Seriously though it definitely looks like many people's dream exhaust.
      I would say too bad it'll be heard & not seen, but I'm sure it'll sound good as it looks.
    20. #1360
      Apr 2014
      Thanks for the heads up on the 1/64” off, I’m on it;-)
      Thank you!
      pat
