    Page 62 of 80 FirstFirst ... 12 52 57 58 59 60 61 62 63 64 65 66 67 72 ... LastLast
    Results 1,221 to 1,240 of 1589
    1. #1221
      Apr 2014
      I installed the steering column and the custom thicker grip steering wheel I made a few years ago. The thicker steering wheel is so much more comfortable then the thin original.
      Pat
      https://www.facebook.com/49591394078...22?d=n&sfns=mo
    2. #1222
      Feb 2014
      This is more art than car. I'm blown away.
    3. #1223
      Outstanding!
    4. #1224
      Sep 2013
      sw Kansas
      Lots of pretty parts. I like the fact that you leave the key in it. I can stop by and go for a drive when I'm close by.
    5. #1225
      Apr 2014
      Quote Originally Posted by Bob in St. Louis View Post
      Thank you Bob! I just hope it’s rolling art one day ;-)
      - - - Updated - - -
      Outstanding!
      Thank you Andrew, I appreciate that!
      - - - Updated - - -
      just let me take it out for the first time;-)
      Thank you!
      pat
    6. #1226
      Apr 2014
      Installed the right side vent and door glass this week end. Very happy with the aftermarket power window regulator.
      Pat
    7. #1227
      Sep 2013
      sw Kansas
      You purchased NuRelics?
    8. #1228
      Was it fun? Lol Must be nice to have the first door done.
    9. #1229
      Apr 2014
      Yes, and I’m very happy with the Nu-Relic. We used Electric life On my sons bulllitt mustang and we’re not happy with them. The engine needed to be running to give it enough power to fully go up and down, and even then they would struggle.
    10. #1230
      Apr 2014
      It’s all fun until somebody puts an eye out ;-) I only hope the other 3 go on and work as smoothly.
      Pat
    11. #1231
      Sep 2013
      sw Kansas
      I used Nu Relics on my 51 because of not finding a bad review on them. One of my friends that builds lots of cars recommended them, also. I did have a wiring harness problem but they took care of it. When you would use one of the switches, it would blow the fuse. When I called in, they had me check the wiring with colors. My harness didn't have those colors in it.
    12. #1232
      I have the Nu Relics going in my car, looking forward to the time I will be wrestling with My Windows.
    13. #1233
      Apr 2014
      I Installed the passenger side rear window and trim. The AMD quarter glass was a heavy 1/16” taller on the rear 12 inches compared to the original. So I had to sand it down with a DA sander to get the best fit. All of the AMD glass has a rough finish on edge so I use the DA sander starting with 60 grit and working my way to 180 to polished edges that shows.
      Pat
    14. #1234
      Feb 2014
      I continue to be blow away with every one of your posts!
    15. #1235
      Jun 2016
      Looks like you’re getting close to having a sealed off cabin. 🥳
      I’ve learned so much from this thread.
    16. #1236
      May 2012
      Kansas City, Missouri
      If that glass is tempered be careful sanding it down. You will explode it into a million pieces. I work in the glass industry and sometimes u can sand them down quite a bit then the next day they will explode. Tempered glass is touchy
    17. #1237
      Apr 2014
      Thank you Bob!
      - - - Updated - - -
      Quote Originally Posted by Toccoa View Post
      Getting close should have the front windshield in in the next few weeks!
      Thank you!
      - - - Updated - - -
      Quote Originally Posted by thumper877 View Post
      I come from a family of Glaser‘s my father, brother, and two uncles we’re all in the glass business. Wonder how I ended up in the boat business ;-)
      Thank you!
      Pat
    18. #1238
      Apr 2014
      Another big part out of storage and bolted on the car. Little by little taking shape;-)
      Pat
    19. #1239
      You did a great job gapping the trunk. Getting close!
    20. #1240
      Sep 2013
      sw Kansas
      I like the way you protect your parts. It's obvious that you have done this before and probably have learned from that. The phrase "you can't be too careful when assembling" comes to mind.
