    Page 11 of 80 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 21 61 ... LastLast
    Results 201 to 220 of 1589
    1. #201
      FRANCE
      Country Flag: France
      Come on Pat, you really got awesome skills...
      You definitely have to come to France in vacations to help me with the Bird ^^
      Amazing work...
      Gil
    2. #202
      Nice job on the tunnel, even from the bottom it will be tuff to know its been modified.
    3. #203
      Apr 2014
      The biggest part of the trans tunnel is finished and all that is left is lifting the aft end of the tunnel to meet the new height of the trans tunnel. But before that I’m starting on the cross member that will be made from 3/8 aluminum, I’ll post a few drawings of the cross member design soon.
      Pat
    4. #204
      Apr 2014
      Test fit the TTI headers and they fit great! Left side just touches the corner of the starter but there are no gasket installed yet and should clear when in. I also started on the cross member by making a plywood template. I should have it mocked up over the weekend and make the aluminum cross member next week.
      Pat
    5. #205
      Does it line up with the floor brace or will it have a cantilevered bracket to bolt to the trans mount?
    6. #206
      Apr 2014
      The mount is just aft of the original cross member so you the new cross member will have a cantilever mount.
      Pat
    7. #207
      Ca
      Looks great. Do you plan on running subframe connectors? That is a massive tranny mount. I like the wood template.
    8. #208
      May 2010
      British Columbia
      I like your style , car's looking awesome
    9. #209
      Apr 2014
      Quote Originally Posted by MichaelUser View Post
      Yes, already welded them on. I used US Car Tool subframe connectors.
      thanks
      Pat
    10. #210
      Sep 2013
      Chicago suburbia
      Nothing like a quality build coming together in a clean environment. You, sir, are one mad scientist.
      '69 Charger TT Viper project - SOLD
      '65 Mustang Shelby clone project "almost done"
    11. #211
      Apr 2014
      I finished mocking up the cross member with plywood and will duplicate in aluminum. This design will eliminate the need for the over the trans cross member. I think with a few modifications this cross member could also be used with a stock torsion bar suspension as well.
      Pat
    12. #212
      May 2010
      British Columbia
      You're a hell of a carpenter my friend !
    13. #213
      Jun 2006
      Quote Originally Posted by keepat View Post
      I don't like your starter clearance, I think you will be asking for issues. Check out this thread: http://board.moparts.org/ubbthreads/...1709968/2.html
      The application for the starter of choice is 2005 ram 2500 5.7/5spd. I bought one from my local auto parts store, it did not clear my 440 so I returned it for credit. I hear it works quite well for the Gen III Hemi and will give you plenty of clearance with the TTI headers.
    14. #214
      Apr 2014
      That is a cool little starter, Thanks for the info and link!
      Pat
    15. #215
      Apr 2014
      Had a friend weld the aluminum cross member for me and I think it looks great! With a little adjustment it fit as good as it looks!
      Pat
      I add a flange at each end and I need to weld on the end caps to the original cross member. Also reused the original crush brace for the new hole I added for the cross member.
    16. #216
      That came out great! Nice design.
    17. #217
      Apr 2014
      Thank You!
      For anyone interested here is a drawing of how I think this cross-member could be made to work with a stock torsion bar suspension.
      Pat
    18. #218
      Apr 2014
      Cut the aft end of the trans tunnel and tacked it in place and now it is looking close to original.
      Pat
    19. #219
      Nice! It blended right in.
    20. #220
      Apr 2014
      Thank you! i'm hoping the stock carpeting will still fit, i'm told by others who have done similar surgery to the trans-tunnel that it will.
      Pat
