      Coolant Temp Sensor Location
      On the coolant sensor that's located on the left head at the front; can it be relocated to the opposite head at the back? I'm concerned that the flow isn't the same at that area thereby causing problems.
      BTW, is this sensor just for the computer or is it also for gauges?
      Apr 2012
      Woodstock, IL
      Yes you can relocate it there. And it's for the computer, but also the gauges if in a stock vehicle.
      Your gauge will need a separate sending unit installed.
      -Dale
      SchwartzPerformance
