    Results 1 to 17 of 17
      May 2013
      qld Australia
      Country Flag: Australia
      Any QA1 reps here?
      Need to speak to a QA1 rep asap please, Problems with my near new shocks
      Mopar or no Car
      Your either with us or Behind us
      Lawrenceburg, TN
      May 2013
      qld Australia
      My charger has only done 4000miles since I rebuilt whole car, I noticed a bit of play in the front end and this is what I found. I am trying to find out why this happened? and if QA1 can help me out here or the company I bought them off. Car has never been raced, or driven hard. This is the front driver shock, the front passenger is not as bad but almost on its way out.
      Mopar or no Car
      Yankton, SD
      Is that rubber or urethane surrounding the ball?
      May 2013
      qld Australia
      Quote Originally Posted by feeble View Post
      polyurethane
      Mopar or no Car
      Indiana
      The blowed out polyurethane would cause noise, but not any play in the steering or anything like that. If you are feeling that kind of movement while driving, keep looking.
      We always had problems with poly bushings in a "loaded" shock [coilover or shockwave] on a heavy car...that's why we went to a kevlar lined bearing. Smooth movement, no wear out, no noise. If I am not mistaken, the QA1 body will accept either poly bushings or bearings...ask if they can switch you over to bearings.
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
      May 2013
      qld Australia
      I did not hear any noise, but when car was off ground you could grab LCA and lift it up and down about 1/8". The play in the steering I found was actually the passenger tie rod ball end has play, so replacing that as well.
      Hopefully they will help me out
      Mopar or no Car
      May 2013
      qld Australia
      Quote Originally Posted by bret View Post
      Just had a look, the housing on the shock where the poly bush goes is actually damaged as well so for it to be used again would need to be welded up and machined, and I think it would be cheaper to get a new shock.
      Which brand shock with the Kevlar bush does ridetech use?
      Mopar or no Car
      Apr 2012
      Woodstock, IL
      Any QA1 reps here?
      Ridetechs shocks are manufactured by Fox
      -Dale
      SchwartzPerformance
      Apr 2014
      Hi Ben,
      Dave Kass here with QA1. We received your email from this weekend, and you should have a response in your inbox. We have a few questions for you in regards to the suspension travel and a few other related items. We will make sure this gets sorted out for you.
      Thanks!
      Dave Kass
      QA1
      May 2013
      qld Australia
      Thanks very much dave much appreciated. I have continously tryed to contact magnumforce with no luck
      Mopar or no Car
      May 2013
      qld Australia
      Quote Originally Posted by David12460 View Post
      Hi Ben,
      Thanks!
      Dave Kass
      QA1
      Dave,
      I did get an email from Damien, but he only stated that he can send me new bearings, he did not ask any questions though. I sent back saying that the shock housing is damaged and bearings will not work
      Mopar or no Car
      Feb 2012
      Yuma, AZ
      We had a Cuda with RMS installed and the same issue. 700 miles on the system and the eyelets were ovaling out, plus 2 of the shocks where leaking. We immediately upgraded to ridetech Coil overs and the owner is thrilled.
      May 2013
      qld Australia
      Good to know thanks
      Mopar or no Car
      May 2013
      qld Australia
      Dave, Damien,
      I sent that email on the info you needed, any luck? is that all the info you needed?
      Mopar or no Car
      May 2013
      qld Australia
      Oh well, bummed out a bit here, looks like no one is going to help me out here, near new shocks destroyed and probably have to fork out for more new ones. looks like the car will be up on stands for a while longer
      Mopar or no Car
      Indiana
      We can trade those in. Contact me at [email protected]
      Bret Voelkel
