    Results 1 to 9 of 9
      FRANCE
      Country Flag: France
      How do I support my Bird to replace body mounts ?
      Hi Guys,
      Here is the nooby question.
      I have 4 jack stands, 1 hydraulic jack and a bottle jack.
      Here is what I have found, do you think it's correct ?
      So 2 under the rear axle and 2 under the rear of the subframe by the transmission crossmember ?
      Do I need 2 more jack stands to put under the front of the subframe by the bumper ?
      Then use a jack and block of wood to raise the body enough to change the mounts ?
      Change one side at a time & loosen only the side you change ?
      Do you think it's correct & how do you do it if not, please ?
      Thank you very much
      Gil
      Central CA USA
      One side at a time, but loosen all bolts.
      Jack stands under the rear axle.
      Place a jack stand under each rocker panel, place a foot long 2x4 between stand & rocker, they are easily dented, push the 2x4 up against the pinch weld. Support rear of subframe on one side & loosen all sub bolts a turn or two. Loosen or remove the bumper brace bolts at the frame, monitor fan to shroud clearance & remove the fan if it hits. Check distributor cap to firewall, you may have to pull the cap, but that's usually ok on a sub mount R&R.
      Remove the rear bolt & lower jack enough to change the mount, you may have to loosen the other two bolts more. Install a new bolt, tighten a few turns then move to the middle mount, repeat, then do the front. Repeat on other side, but keep an eye on the fuel & brake lines at the rear of the subframe. re-center the sub using the alignment holes on each middle mount.
      On the left side watch the steering rag joint & don't separate the sub too far. Loosen the steering box frame bolts if the rag joint is stressed.
      Lawrenceburg, TN
      Quote Originally Posted by David Pozzi View Post
      Place a jack stand under each rocker panel, place a foot long 2x4 between stand & rocker, up against the pinch weld. Support rear of subframe on one side & loosen all sub bolts a turn or two. Loosen bumper brace bolts at the frame, monitor fan to shroud clearance & remove the fan if it hits. Check distributor cap to firewall, you may have to pull the cap, but that's usually ok on a sub mount R&R.
      Remove the rear bolt & lower jack enough to change the mount, you may have to loosen the other two bolts more. Install a new bolt, tighten a few turns then move to the middle mount, repeat, then do the front. Repeat on other side, re-center the sub using the alignment holes on each middle mount.
      ^^^^ this
      FRANCE
      Thank you VERY MUCH David (& Rod).
      I'll have to translate in French carefully first as it is very technical & will have to be very carefull also when I do it.
      I really love this site for this........... So nice......
      I'm really honored I (a French guy with little skills & few tools) can chat with a racer & I can learn from him....
      Haven't got the words in English as I'm not very fluent but thank you very much to read & take from your time to answer & share your knowledges.
      So cool that gives me the big motivation to work on my car.
      Have a nice day guys
      Gil
      Mar 2012
      New Jersey
      Not to hijack this thread, but should a similar method be employed for those of us with full framed cars? Cause I'm looking at replacing my Chevelle's body bushings and not 100% sure how to do it properly.
      FRANCE
      Hi there newby question again about torque specs for my factory rubber body mounts, here is what I found, do you think it's correct for the first gen. F body ?
      4 body to frame mounts 75-95 lbs ft
      2 core support to frame mounts 30-40 lbs ft
      Thanks again guys
      Gil
      Dec 2009
      I found this very helpful. Spray some PB blaster days prior to removal attempt, mines came out really easy without any issues.
      FRANCE
      is it relevant to mix body mounts ?
      Heard that stock radiator core suport was subject to crackings when using solid body mounts ? Myth or not ?
      is it relevant to mix with front poly bushings for the rad. suport to avoid cracks & use solid alu. for the four other holes ?
      Gil
      FRANCE
      Hello all,
      Before starting the body bushings replacement the driver side frame alignment hole wasn't centered,
      Then I replaced the bushing & the alignment hole still not centered,
      but I measured diagonally from a hole @ the front of the leaf springs to a hole @ the core support
      then another measure from the holes @ the front of the leaf springs to the frame alignment holes
      and frame is squared...
      is it an issue that the driver side frame alignment hole is not centered?
      Gil
