      Oct 2011
      coilover angles help!!
      did some searching and cannot find any info. i know typically you angle the tops of the coilovers in toward the center of the car or straight up and down. would it be ok if the bottoms were toward the center of the car a small amount say 1" inward compared to the tops of the coilovers??
      Jul 2010
      Sacramento, CA
      Ideally you want the lower attaching point if the coil over to be as close as possible to the lower ball joint, but theres no reason it wouldnt still function at almost any angle.
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      Apr 2012
      Woodstock, IL
      The angle doesn't matter that much, but the mounting matters- generally the frame rail is further inboard than the lower shock mount which is stronger than a random tube further outboard, generally. Not sure what your frame looks like.. Also, the shock could interfere with the upper control arm or tire depending on the relationship of the upper to the lower mount.
      -Dale
      SchwartzPerformance
      Oct 2011
      ok thanks. basically whats going on is the car used to have a ladder bar/coilover setup and im moving to a self engineered 4 link / panhard/ coilover setup. the axle mounts for the coilovers and 4 link are inward about 1 inch from what the ladder bar mounts used to be and i was hoping to not have to move the upper coilover mounts. next just gotta figure out my panhard placement and ill almost be back on the road
      Apr 2012
      Woodstock, IL
      Oh ok yeah in the rear you'll be ok- good luck
      -Dale
      SchwartzPerformance
      Dec 2011
      Planit Oahu, Hawaii if you don't belive me check shipping prices
      the angle only effects the spring rate needed, the more angle you have the higher rate you will need. AFCO has a chart on their web-sight.
      Oct 2011
      Thanks guys i really appreciate the help.
      Quote Originally Posted by RNation0001 View Post
      Since you are Fabbing up the System, can you Make new mounts?
