      new york city
      Leaking head gasket
      I have a 496 big block Chevy.
      I have done a pressure test on my cooling system and it does not hold steady pressure, I also have some white gunk in my coolant and my oil is not milky-looking.
      So, I suspect I have a head gasket leaking. Is there a way to determine which side of the engine it's coming from?
      Or which cylinder without tearing both heads off?
      Thanks in advance
      Dec 2010
      Fredericksburg, VA.
      You might consider doing a leak down test on each cylinder and see if one cylinder is leaking into the cooling system.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
    Tags for this Thread
