    Results 1 to 20 of 31
      Nov 2012
      Birmingham, Alabama
      'Maybelline' 1963 Corvette Convertible
      Meet 'Maybelline', a 1963 Convertible that has been named such due to all previous repairs being either covered up or misrepresented..."Maybe It's Maybelline"...as the commercial so states!
      Well, initially I thought I had a nice 63 convertible with a 67 theme (performed by a previous owner) to work with and due to that, I had planned to build the car into an L88 clone. However, after fully inspecting the car it quickly became apparent that everything I was told about it was false. While the car still retains it's 63 VIN spot welded in place, I have to wonder if this poor car once resided on the bottom of an Ocean somewhere?!? Either way, it doesn't much matter now, I am repairing the car and it will become something special, but no longer an L88 clone!
      As purchased. Pictures can be deceiving!
      [/IMG]
      My first find was that the luggage rack extensions had been cut, for some odd reason, and that the luggage stop was missing!!!
      Something fishy was going on here! Initially I thought someone had taken the front of a passenger sill/rocker channel and installed it on the rear of the passenger side. HOWEVER, it turned out that the donor rocker section that was spliced in was rotten at the rear and someone had taken the front portion of either a passenger or driver rocker channel and had poorly attempted to weld it into the donor rocker section to provide a solid rear section for the # 3 body mount.
      Initially, I thought the rust in the birdcage wasn't horrendous, but it would still need a small amount of repair. The very honest seller(heavy tone of sarcasm), told me it only needed one section repaired in the sill and it was about an 8 hour job...sure, removing the front end, repairing the outer windshield areas, and replacing the driver sill and fabricating steel and reinforcing the lower a pillar is an 8 hour job....times 20.
