      Apr 2010
      Portland, OR
      Brake options for the ignorant
      Well I thought I had my brakes figured out but after getting the timing dialed in I just don't have enough Vacuum to run power brakes. If the motor is reving and I press the brakes they are fine if I come to a stop with the clutch in slower speeds feels like I have a bunch of air in the line.
      This is my setup - this is all new maybe 110 miles on it.
      1 inch Wilwood Master
      Stock 73 Firebird booster
      Wilwood prop valve
      C5 front and rear brakes
      Hawk HPS pads
      I'm making 14-15 vacuum
      If I just wanted to get a strong "feel" for manual brakes could I use the 1 inch master? Just take the booster out and push everything back (hopefully I don't need new lines.) From reading countless threads 7/8's seems like the way to go. I just don't know if manual is what I want but I don't want to drop another grand into this car for hydroboost or cam this summer. Another option is an electric vacuum pump which I almost ordered. Thinking it would work for the summer while I'm fixing the rest of the little crap. I had the car at shops for two years they did some good stuff and some half ass stuff so this is just one of many projects on what should have been a street ready car awhile ago!
      Bobby
      1973 Firebird 466 Pontiac, T56, C5 Brakes, PTFB and Hotchkis suspension
      2011 Camaro SS Supercharged, ZL1 body and brakes, Z28 suspension.
      Apr 2012
      Woodstock, IL
      Yeah you'll likely need to step down to 7/8. The pedal will be pretty hard to push with the 1" you've got.
      It's obviously the cheapest route to go, or do the electric vacuum pump idea.
      -Dale
      SchwartzPerformance
      Apr 2010
      Portland, OR
      Quote Originally Posted by Schwartz Performance View Post
      -Dale
      If the Electric vacuum pump from SSBC would work and the only problem was a little compressor noise (I'm assuming kind of like an electric fuel pump) then I'd be all over that for now. I hate dropping another grand into the motor for a cam when I'm not sure if I'm going to even keep this setup. I'd really like to daily drive the car this summer and just enjoy it. Once I get some miles on it then I could dial in the rest.
      I've found very little on the vacuum pumps other than "they work great" and "Not a good solution"
      Dale have you used them in cars? What was the experience?
      Thanks for the reply!!!
      Apr 2012
      Woodstock, IL
      Yeah we've used them in a few cars. They do make a lot of noise, more like an air ride pump than a fuel pump.. And I'd recommend a decent sized vacuum reservoir especially if you're one to pump the brakes a bit up to a stoplight, as opposed to pushing once and holding until you're stopped.
      -Dale
      SchwartzPerformance
      Jun 2006
      Katy,TX
      Although different fron caliper diameters but the factory manual disc MC was a 1" but moved the pedal up to get a better ratio from the lower hole for power brakes.
      14-15" has always run power brakes for me, maybe a bad booster? The dual diaphragm 79-81 Trans Am 4WD booster has worked down to 10" for me.
      1965 GTO project car
      2004 Pulse Red GTO
      Apr 2010
      Portland, OR
      Yeah Skip I might just try to take the booster out and see what it feels like. I've tried a 9 inch dual diaphram with same results. The only thing that works is if I advance the timing a bunch to get more vacuumm then I get some brakes. I'm trying to decide wether to order my 4 willwood MC and go manual or just bite the bullet and do a different cam or Hydratech Hydroboost. Leaning toward the hydroboost or manual brakes I really don't want to mess with the motor.
      I really researched the pumps today but there was a lot of feedback about REALLY noisey pumps and faulty sensors.
