Results 1 to 20 of 631
My 68 Cougar Pro-Touring / Resto-Mod Project
I've been working on this project for some time now . This project started when my brother in-law gave me this Cougar that he'd owned since 1969 . He took it off the road approx. 20 years ago when it started running rough and he couldn't seem to figure out why . The guy I sold the pure stock 289 to for $200 informed me that there was a hole in one of the piston tops . I've torn it down to a bare shell and have been repairing any rust damage that I have found , which has been found in the rear quarters and front torque boxes. I have replaced the complete stock front suspension with A TCI front suspension kit including cross-member , tubular upper and lower control arms , ridetech coil-overs , power rack and pinion , sway bar , 2" lowering spindles , and Wilwood disc brakes . I've installed a Detroit Speed mini tub kit , sub-frame connectors , and rear torque boxes . I plan to install the Detroit Speed Quadra-Link rear suspension when I have the $$$$ . As for the power plant I have installed a GM 6.0 LQ9 LS motor and a 4L65E transmission . I've set the motor back as far as I could without getting silly , that being said I've modified the firewall and have fabricated a whole new trans-tunnel . I've had to do some minor body work . My recent project has been replacing the rear tail-light section sheet metal and welding in a 68 Shelby Mustang tail-light panel. I've always thought that the Cougar tail-light looked really heavy on the eye. Pictures to follow .
11-01-2014 #2As promised
07-18-2017 #3
- Jun 2016
- 24
Hi those appear to be the mini tubbed inner wheel wells. Can you talk more about that area for me? Do you have more pics of it underneath. I'm doing the same thing right now, but I'm not sure how much more to pinch against the frame well. I also have a big gal towards the back of the passenger side outer wheel well to new one
07-18-2017 #4https://youtu.be/A4Jy9doSuCk
I can do better than pictures , here is the Detroit Speed install video . I've watched it a 100 times . The mini tub kit comes with an install DVD . The mini tub kit comes with new frame rails to make room for the new tubs . If you're working with a Cougar , you need to modify the rear section of the tubs .
- - - Updated - - -
Thanks Michael !
07-19-2017 #5
- Dec 2009
- San Diego, CA
- 235
