    Results 1 to 1 of 1
      Knoxville TN
      SSBC Combo Master Cylinder/Proportioning Valve
      This master cylinder is used with a few minor scratches, but still in good condition. It has a 1 inch bore, brake switch wire (I never needed it) and built in proportioning valve to keep a clean look in engine compartment. I do not have the 2 short brake lines that come with the kit as seen in the picture on the Summit Racing website and the brake switch line is a little melted as seen in pictures, but should still be useable. I used this on my 1968 Camaro and it worked good once it was pressure bled. I say this because I could not bleed it by hand or foot for nothing. SSBC says bleeding can be difficult sometimes because of the built in prop valve. I finally used a good pressure bleeder called Speedi Bleed which worked amazing. If sold locally I will pressure bleed at no cost. This sells on Summit Racing for 565.00 I am asking 220.00 shipped. http://www.summitracing.com/parts/ssb-a0473-1/overview/ Need anymore info or pictures contact @505-670-7063 Knoxville TN thanks. Adam
      Name:  new size 5.jpg
Size:  102.5 KBName:  new size 6.jpg
Size:  78.9 KBName:  new size 7.jpg
Size:  89.2 KBName:  new size 8.jpg
