      Apr 2011
      Missouri
      Another Firewall Smoothing Question -- Order of Operations
      I searched and searched, but didn't find a specific answer to what order to get to smoothed firewall. This project is a long, drawn out operation with my youngest son and myself -- 6 years and counting. We're making progress, albeit, slow. Takes time and money and both are often hard to come by. Enough said, the question is: Do I need to purchase the Vintage Air unit and mock that up before adding panels on the firewall? This is on a GM A-Body car, a 1971 Olds Cutlass Supreme. I've read the Vintage Air install manual and it seems there bolts that go through the firewall. I've attached my firewall and an excerpt from Vintage Air installation manual.
      --GaryB
      Apr 2012
      Woodstock, IL
      Looks like you're right. We usually weld bolts to the inside of the firewall so you can't see them from the engine bay.
      -Dale
      SchwartzPerformance
      Nov 2009
      Austin Texas
      Is that the sure fit system or the magnum?
      Dec 2009
      Carson City, NV
      I smothed my firewall first then used these http://www.mcmaster.com/#weld-bolts/=ral3se (Perforated Base Studs) to attach my VA Unit
      Mar 2012
      Texarkana, TX
      I purchased a mock-up Vintage air unit to make sure I put it in the right spot. Depending on how you are going to smooth your firewall, you may end up mounting it a bit differently than it would if you didn't change it. The mock-up units aren't very expensive.
      63 Biscayne
      Schwartz Performance Chassis
      My build thread: https://www.pro-touring.com/showthre...ht=#post916553
      Feb 2006
      Tennessee
      Quote Originally Posted by renegade6 View Post
      ^^^This, the mock kit was only $58 shipped for me. Once I'm ready to buy my system, if I'll send the mock kit back they will credit my account the cost minus shipping.
      66 Chevelle - LS-Leap
      LQ9 / T56 Complete - Phase 2 in process!!
      https://www.pro-touring.com/threads/...t-LS-Heap-quot
      SC&C, Kore3, Detroit Speed, BBS, Advanced Induction, TickPerf, Currie, Moser, Holley, Hellwig, Edelbrock LS-Kit, Mast, Wilwood, BP-Automotive, StopTech, Ridetech, Hotchkis, UMI, Energy Suspension, AAW, B&B Classic's, PPG, Aeromotive, Canton, C&R, Sparco, Ididit, Spectre, Bridgestone, DakotaDigital, Alpine, RockfordFosgate
      Santa Clara, CA
      2 FYIs--If you are converting to a hydraulic clutch you might want to consider welding in the clutch master cylinder bracket, and if you are re-wiring the car, you might want to double check that the fuse panel of the replacement wiring system is the same size as the original. On my 67 Camaro the AAW fuse panel is slightly larger and it would have been good had the builder caught that before the bodywork was buttoned up.
      Steve
      Apr 2011
      Missouri
      The plan is to use separate master cylinders (front, rear and clutch) similar to what Tim is using on his project "The WidowMaker".
      As for the electrical, current plan to use a 3-cell ISIS system. That's good to know about the 'mock-up' unit available from Vintage Air. I'll check on that. I did see another post where some vertical braces were welded from the toe-board up against the firewall on the inside to create a mounting bracket to the Vintage Air.. That way, nothing had to go through the firewall.
      GaryB
      Current Project: 1971 Oldsmobile Cutlass Supreme
      Current plans include: Full RideTech Coil-Overs, Olds 455, Holley Terminator EFI, Edelbrock heads, Tremec T56 Magnum, custom dash, custom console, Dakota Digitial VXH-1017 gauge cluster, manual brakes, 3.42 gears, etc...
