      St. Louis, MO
      Wilwood Master Cylinders
      Has anyone used/or is using the wilwood dual master cylinder setup for your brakes, one for the front and one for the back? How well does it work, are you satisfied? I am most likely going to use C4 fronts and rears since I am using a C4 Wayne Due Frame and C4 Rear. The car is going to see mostly street use. I am welding a new firewall in out of sheet, and am starting from scratch. This seemed to clean up the firewall the best. Thanks.
      1978 PONTIAC TRANS AM : '02 LS1 w/ T56, Wayne Due Front Clip, Wayne Due IRS, 2002 TA Interior.
