      Jul 2012
      Mooresville, NC
      Primer on Powdercoat Parts
      Body shop got primer overspray on my DSE powercoated lower control arms. Aint real happy, but what do you do when the body shop gave you a dang headache the entire time anyways. The overspray is not horrible, but anything less than perfect bothers me. I am assuming if I get the primer overspray off I can simply buff the shine back on the powdercoat. Any recommendation on how to remove the primer? You can buff the shine back on the powdercoat correct?
      Jonesboro, Arkansas
      You can buff most powder coat, if the overspray isn't too bad I would try using a lacquer thinner rag and make quick strokes and not let it sit too long. I've done this on some of my powder coated parts. Take your time and be careful though. I think, your going to be fine..
      Carl Wilson
      May 2010
      kitchener,Ontario,Canada
      Try using a clay car, used one on my Cadillac for overspray...it worked
      Ryan Austin
      Powder coating is incredibly resistant to just about any chemicals. Try mineral spirits. Once the overspray is off, follow up with windex.
      Nov 2010
      Pittsburgh, PA
      I do powder coating and if you have gloss black, try clay bar first. Laquer thinner wil leave surface marks. If the clay bar doesn't work, use a product called GON. You can get it at a paint supply store. Apply a small amount on the rag and wipe the overspray off. It also works great for getting yellow road line paint off your inner fender wells and body.
