    Page 2 of 2 FirstFirst 1 2
    Results 21 to 26 of 26
    1. #21
      Sep 2007
      Montgomery, Tx
      Yeah for me also, some are lucky enough to have their company pay for it.
      Gary Rys
      69 Camaro
    2. #22
      Oct 2007
      Newark DE
      Pick a cross shaft, pick a ball joint, pick tube size and build a jig. (not my pics) These are from a C6 based GTM build. First is rear arm, last two are front. Hope this helps. Here is the photobucket I stole these pics from http://s926.photobucket.com/user/jch...?sort=6&page=1
    3. #23
      Jan 2014
      San Francisco, CA
      http://www.spcalignment.com/images/s...t_2013-web.pdf
      Starts at page 114. This can probably get you where you need to be. Ive hobbled kits together for odd cars a few times with these.
    4. #24
      Oct 2012
      That catalog is a great go-to for parts! However, it did spawn another question.
      Is there any benefit/problems with longer vs shorter control arm shafts?
    5. #25
      Oct 2012
      Anyone have an answer for me? Please?
      I would assume that the wider control arm shaft would be better for arms with more clearance for things like shocks, coils, or bags. Maybe stronger against torsion "wrapping" when the brakes are applied? Smaller arms for tighter situations...
      Any of these assumptions correct or does someone have some information that would help?
    6. #26
      Nov 2009
      the dirty mitten
      You are correct, no geometry advantage to having a wider cross shaft, only for packaging purposes. The pivot locations will be on the same plane, regardless of their distance apart
      Steve
