    Page 2 of 2 FirstFirst 1 2
    Results 21 to 30 of 30
    1. #21
      Feb 2009
      muggy midwest
      The spal controllers can't handle HO factory style fans-simple as that. With each "version" they got crappier. I stick with my own 3-speed resistored design so parts can be found at any GM dealer or parts store. I got sick of dealing with every bodies "version 8.0" or "redesigned this...." just tells me nobody can't get it right. Since I build my own harnesses I've dropped off buying pretty much all aftermarket fan controllers. I do have to say in the past I really liked the DC Controls unit....always worked for me. But again....always changing the design...
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
    2. #22
      Mar 2010
      Do you sell your controllers?
      Quote Originally Posted by H2Ogbodies View Post
    3. #23
      Feb 2009
      muggy midwest
      Sorry I don't get time to check this site very often. I'm a vendor on another forum but yes, if you're interested in information on my harness work, PM me with what you're working on-I'm more than willing to help out.
      I build replacement accessory harnesses both for accessories like power locks/windows as well as cooling system harness with various configurations of relay control.
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
    4. #24
      Jun 2014
      Harrisburg, PA
      Quote Originally Posted by Barrrf View Post
      Forgot about this thread - I finished installing the fans on Saturday. I ended up buying the Derale 2 fan controller. So far its worked flawlessly.
      Curious which Derale unit you bought. I am seriously considering one of their dual fan/shroud setups. They recomended to me their controller that has the sensor that goes either between the tubes on the radiator of into a bung in the radiator and keeps the car at constant temp to match your thermostat. In other words if you have a 180 stat in there the car will remain a constant 180. They said it is a little pricey but woks great.
    5. #25
      Newbury Park, CA
      Derale has a new pwm that is quite good and can handle any fan thrown at it.
      http://derale.com/products/electric-...n-probe-detail
    6. #26
      Jun 2014
      Harrisburg, PA
      That is the unit they strongly recommended that I get.
    7. #27
      I am in the process of rewiring my fans (using stock 99-02 camaro dual fan). I am using 2 relays and the PCM with factory temp settings....I spoke with Mark at S&P and he advised that I go to a temp probe with adjustable temp control switch. I realize that the stock temp set points are much too high and I need to either send the PCM out to have the settings changed or go with Mark's recommendation.
      Can someone explain the advantage of pwm? It allows a more steady control of temperature so that the fans don't just run at 1 speed and constantly turn on and off?
    8. #28
      Feb 2009
      muggy midwest
      Hmmm....that DeRale looks suspiciously like DC Controls unit but a prettier package and a potentiometer for temp adjustments.....presumably all to skirt Brian's patent designs on his. Funny how Brian started this whole pwm fan control market....lol. Anyway, PWM uses reference voltage via temp probe to limit how much resistance to ground the fan(s) sees-thus altering its speed. This is why the negative supply wire for the fans are 10ga and the supply voltage is 12ga. Does this work? Yes, but as usual all controllers build heat since they are constantly building/releasing resistance so how they shed heat is the most important part of their construction IMO.
      I still prefer to use relays only because their designs never change, get redesigned or go obsolete. I use fixed resistor coils to give my fans up to 3 speeds and parts are available at any parts store or GM dealer. I gave up on PWM controllers quite awhile ago-DeRale is just the newest kid on the block. If you use any controller, I always suggest wiring in a relay backup just in case and that begs the question-if a tried and true relay system is the best backup, why not just use that as your primary control then?
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
    9. #29
      Feb 2009
      muggy midwest
Size:  188.9 KBName:  IMG_20140709_211837_531.jpg
      Here's a pic of one of my Mark VIII fans outfitted with my 3 speed resistor harness. Using 2 simple GM 3/8 NPT temp switches, you gain low, medium and high speed bypass through the use of my 4-gang relay bank with fan speeds adjusted by a GM blower motor resistor board. AC use or a manual override bypasses the resistor board and runs the fan on high speed.
      This setup converts ANY fan or dual fan setup to operate with 3 speeds with this configuration. I'm running this setup in my 86 K10 short box, my 80 Monte,....I just finished converting a set of LT1 fans in a 57 Nomad to a 3 speed operation. I also recently ran this setup on a 69 Camaro as well. The best part? All easily accessible parts once you have the kit installed. My relays are diode/resistor equipped commercial grade TYCO but in a pinch you can use standard ones.
      Temp switches are easy to get-as is a replacement blower resistor board should it for some odd reason ever fail. I've put this kit through a lot of testing and so far never any issues. I even incorporate high heat wire loom and correct rosebud clips and loom ends! Anyway, if anybody is tired of using "controllers" PM for info on this setup-you can also use your PCM to run this setup also as long as you have 2 ground outputs.
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
    10. #30
      Feb 2009
      muggy midwest
      This is my 3-speed resistor setup on an LT1 fan assembly for use on a 70-81 F-Body. I also use both MIDI style fuse holders and Delphi 630 series inline ones as well.
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
