Results 1 to 17 of 17
Thread: My car stinks!
03-05-2014 #1
My car stinks!
I have a 67 fairlane with a 289, fairly large cam, edelbrock performer heads and a 600cfm holley double pumper. When I sit at stoplights I can smell rich exhaust, when I park in my garage, the garage will stink for days, when I pass bus stops, i can only assume I leave people teary eyed and choking. I occasionaly notice the exhuast smouldering when I shut the car off.
below are the things I have verified so far:
float levels are correct
power valve is not blown (it is a 5.5)
manifold vacuum at idle is around 10" around 900 rpm.
jetting is 64 front 71 rear - 2 sizes bleow stock and I am at 4000ft elevation.
Timing - I don't have a timing light but I have set timing to run where the vacuum is the highest.
spark plug condition - sooty on the tip of the electrode, and the end of the threads, but the porcelain and ground strap are clean.
fuel leaks - none that i can find.
vacuum leaks - none
idle screws 1.5 turns out, engine begins to stumble at .5 turns out
I know this carb is supposed to run a little on the rich side anyway, but is there anything I can do to make this car a little more pleasant to be around?
Zach
