      May 2007
      Megasquirt Fuel Injected SBC setup and TH350
      I have a basically rebuilt and complete 355 SBC setup for fuel injection for sale that is a stout and fresh motor. The motor has 10 mins of idle run time on a carbed setup before switching over to the EFI setup and not run since. Also have the rebuilt TH350 with it.
      Now splitting up with prices listed and will take offers.
      Long block - $900:
      -350 bored .030 over, 10.5:1
      -Keith Black pistons
      -GM Forged crank and GM Pink rods
      -Ported double hump heads with 2.02/1.6 valves
      -1.6 Harland Sharp Rockers and Moroso stud girdles
      -Crane Saturday Night Special solid cam, 518/536, 106 LSA
      -ARP rod bolts and main studs
      -Moroso windage tray
      -Edelbrock gear drive
      I've seen very similar motor combos go low 12's/high 11's in a 3200-3500lb car.
      Motor Parts:
      -Speed-pro forged piston kit,(+10cc, IIRC) brand new in box - $350
      -Fabricated aluminum valve covers - $75
      -MSD 6AL - $90
      -MSD Pro-billet distributor - $170
      -MSD Blaster coil - $20
      -Edelbrock Victor-E EFI intake, LT1 injectors and fuel rails $350
      -Edelbrock TB elbow - $80
      -Hedman longtube headers - $100
      -Flex-lite fan - $25
      -Walbro GSL392 255lph fuel pump - $70
      EFI Setup - $600
      Megasquirt II V3 with wire harness, injector pigtails, most engine sensors, relay board etc. All brand new and uncut and assembled from DIYAutotune w/ 3-bar MAP sensor for turbo setup
      Transmission - $500
      TH350 with a manual valve body with 3500-4k stall converter
      Would like to sell the complete setup but can also work out package deals for parts. I'd like to get $3000 for everything. Motor and parts are in Gaithersburg, MD.
      Sean
      May 2007
      UPDATE: Parts have been split up and priced, trying to move parts and clear out my garage to make space.
      Sean
      May 2007
      Bump, parts have been split up and priced.
      Sep 2007
      Montgomery, Tx
      PM sent
      Gary Rys
      69 Camaro
