Results 1 to 14 of 14
Thread: Hooker Headers 2473-HKR Install
02-25-2014 #1
I just received a new set of Hooker LS Swap headers (2473-1HKR) so I thought I would post a few pics of how they fit. Hooker markets these headers to be used with their engine mounts, transmission mount, and oil pan. I am using my existing DSE engine mounts, along with a home made transmission crossmember and the older style Holley oil pan, so they ARE compatible with other manufacturers mounts.
The fit of these headers is excellent. The clearance around the factory steering box is great, I can put my hand between the box and the header tubes. The headers also easily clear the ridetech Tru Turn system since they are swept back more than typical full length headers. After talking with Todd O'Neil from Holley, I determined that the new Hooker engine mounts position the engine in just about the same location as the DSE "stock location" mounts. As a point of reference, the machined surface on the front of the block is flush with the front surface of the factory crossmember.
1969 Camaro
Engine: 6.0 LY6 LS
Engine Mounts: DSE 060401 "stock location" engine mounts\
Transmission Crossmember: Home Made
Oil Pan: Holley 302-1 Older Style Pan (This required a slight notch in the factory subframe)
Suspension: ridetech Full Suspension with Tru Turn
Steering Box: 3rd Gen Camaro Factory IROC Box
Here are a few pics:
The notch in the drivers side engine mount was from the previous set of Dynatech headers and is not required for the new Hooker Headers.
Plenty of clearance for the Ridetech Tru Turn centerlink bracket.
This pic shows the old Dynatech Headers.
Hope these pics help anyone on the fence about purchasing these headers.Marc Battiste
1969 Camaro
LY6/T56/12 Bolt
