    Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
    Results 61 to 80 of 93
    1. #61
      Jan 2014
      Quote Originally Posted by ragz View Post
      Finished the interior part of the deadener, added a few pieces to the doors, inside of interior rear quarter panels and some up under the dash as well, the door difference is very noticeable, not sure, but once I cut an access hole in my trunk I may do that as well... So, I guess it's on to the AAW wiring harness, hope this goes smooth.. Lol
      Attachment 135040
      What brand/style of sound deadened did you use?
    2. #62
      Feb 2013
      Saskatchewan, Canada
      Quote Originally Posted by ryanleiker View Post
      I used GTMAT pro 80ml
    3. #63
      Feb 2013
      Installed the rain gear, hidden wiper motor, fits great, easy to install and very well put together. I got the variable speed version, the metal knob and retainer were also a nice touch. Now to paint the cover, starting to wish I would have smoothed the firewall... Oh well.
    4. #64
      Jan 2014
      Any reason you picked the 80mil over the 50mil or 110mil?
      Looks like a good product for the money.
      Also, how much did you buy to cover the interior?
      Thanks.
    5. #65
      Feb 2013
      Thanks.
      The reason i went with 80 ml , is when i bought it a few years ago that was as thick as they had. It seems good but i bought it more for the extra water proofing and heat barrier, but i don't see why it would not be a good product. I bought 2 of the large rolls with 2 rolls of tape as well, one roll did all of what i need to do in the interior and i still have a 4foot x18 inch piece left plus the other roll, it sticks great ,contours well ,the interior is certainly less hollow sounding, so, over all i am pleased with it......but i haven't drove 1 foot..
    6. #66
      Feb 2013
      Started on the rs buckets, things seem to be pretty straight forward, only thing not working out great is the AAW rs harness seems way to short ,routed it every possible way and can not get it to work, try again tomorrow,small update pic, i know this is basic stuff and not at all new, but hey its progress.......i can not believe how guys here are so capable of real fabrication ,i find it an uphill battle just to add bolt on stuff,but , it is fun, and frustrating..lol
      Edit: was able to get AAW rs wiring to work by taking apart some of the zip ties that they use and it made the runs longer in some areas, enough to make it work.
    7. #67
      Feb 2013
      Installing the vintage air, not going to put the centre vent in it's original spot, thinking about putting it in the ash tray spot.....
    8. #68
      Feb 2013
      Small amount of progress , test fit va, hoses are measured but not crimped yet, unit is fit, wow it's a tight fit for the ecu and fuse box if you mount them in the glove box, the vents are in, and I think I have a great fit for the vent to go in the ash tray location ,i still have to run the wiring but.....slow progress..
    9. #69
      Feb 2013
      Found some helpful info out today about Dakota Digital VHX gauges, if you are using the OBD2 plug, the way to tell if your OBD2 plug will support oil pressure reading is, if your factory oil sending unit has 2 wires it will NOT support OBD2, if it has 3 , it WILL send pressure reading through the OBD2 cable.I was glad to find i have 3, install just got easier..
    10. #70
      Feb 2013
      Well i have finally finished front end wiring, which has allowed me to install some stuff in the engine compartment.
      -Installed-
      -cold air intake
      -fuel reg.
      -fuel lines
      -catch can
      -air cond/ heater hose lines, rad upper/lower hoses
      -battery
      still have to do brake master and clutch master,not a great pic but...progress
    11. #71
      Feb 2013
      Finally... winter is back and i am able to focus on the car again, i've finished the fuel tank , trunk access to tank , fuel lines, wired the pump and sender, rear of car is wired and now i am tackling the dash.... it looks cleaner than what the pics show but here is the dash area so far
      Name:  20171128_181133 resize.jpg
      This was not the final look , added sound deadener to floor and used different fasteners
    12. #72
      Jul 2016
      Very, very nice!! How do you like the Roto-Fab CAI box ?? I just ordered mine. What Radiator is that ?? Thx!
    13. #73
      Feb 2013
      Quote Originally Posted by DT69Cam View Post
      Thanks, i am totally impressed with the Roto-Fab CAI, it fit well and blends in nicely, over all quality appears to be exceptional, the rad is a BeCool .
    14. #74
      Feb 2013
      A big day for me.....Its hook up the battery check for smoke day...
      Hooked up battery ..no smoke...
      Tried out the headlights ... very nice... well they opened a little iffy..
      Tailights.. ok
      Shut off headlights.. good ..
      headlight doors close..... no
      i hate rs lights..lol
      oh well small steps...(and cause i know someone will notice .. shift light is just sitting on dash , not where its going)
    15. #75
      Jul 2016
      Thank you !!
    16. #76
      Feb 2013
      A update, after re-reading rs limit switch wire hookup , turns out.... i'm a Dummy , changed 2 wires on limit switches and now it's working like a champ, can't even say how stoked i am to see them work, i was worried i would have to change my head lights but they get to stay.
    17. #77
      Feb 2013
      Made the decision that i'm only going to use hood pins and ditch factory hood latch and catch.... so i figured that the bright light indicator on factory gauge cover isn't used with a DD cluster, it may work for a warning light if hood isn't shut..
      using a Alarm Security Adjustable Pin Switch at the hood, it should be a good way not to forget hood open, its very bright and impossible to ignore.. i hope.
    18. #78
      Feb 2011
      dallas, tx
      I like the hood light open idea. How about using that for the shift light instead of the hood opened light ?
    19. #79
      Feb 2013
      Quote Originally Posted by icemanrd19 View Post
      I like that idea too.. but.. knowing me i would have the hood fly up at 6500 and i would miss the shift anyways lol, but no reason it wouldn't work.
    20. #80
      Feb 2013
      So.. time to install DBW pedal, previously i had purchased an iron works bracket as i thought it would simplify pedal install , but, it placed the pedal way to far forward and not in a place that would look good, so, i used the bracket that came originally with pedal and i think it will be just fine.
