      Jan 2014
      Ohio
      Need help finding a Flywheel
      My apologizes if this is in the wrong part of the forum,
      But I'm looking for a flywheel for my 70 Camaro.
      My Camaro has a 86 up small block Chevy with one piece rear main seal.
      And I'm using a 1970 Muncie bellhousing and clutch.
      So it is a standard 11 inch clutch.
      With 168 tooth flywheel
      This is the flywheel I have now
      http://www.jegs.com/i/JEGS+Performan...01256/10002/-1
      I need an aluminum version of this flywheel.
      Or if somebody can tell me what vehicle this flywheel came in?
      Thank you,
      Travis
      Jan 2014
      Ohio
      Found out what I need SC35A Spec flywheel will work.
      11 inch clutch, 1 piece rear main and I believe it is 168 tooth.
      Thank you guys anyway
