    Page 2 of 2 FirstFirst 1 2
    Results 21 to 34 of 34
      Nov 2007
      near Orlando
      I'm fortunate to live close enough and have had Brian do some work for me and get to see this car and others up close. Its hard to find someone with his skill level. Top Notch !!!
      RagRat
      Chris Costa
      Merritt Island,FL
      Thanks for the compliment guys ! Chris, always a pleasure !
      Check out my web site.
      Merritt Island,FL
      Here are a couple updated pictures. We got the dash, tulips and trunk sprayed satin black now we can install the subframe and suspension.
      Jul 2013
      Gilbert, AZ
      Very nice! If you don't mind my asking, what are your front wheel specs, sizewise?
      Merritt Island,FL
      Quote Originally Posted by CampbellshotrodsAZ View Post
      Thanks,fronts are 18x9 275s
      Nov 2010
      Thats almost the same setup I'm using in my '71 Formula, the Chassisworks suspension parts were a good choice in terms of functionality and fit, except that the ride height in the rear is too much for my taste, I got the suspention in the absolute minimum height and still there is at least 2.5 in. of clearance between the finder lip and the tire (using 26 in. tires). Unfortunately, and after many calls to CA Chassisworks, they told I have to just live with it!.
      Merritt Island,FL
      Quote Originally Posted by kamaro View Post
      I agree, that's why I modded the upper shock crossmember and gained an extra 2 in.
      Nov 2010
      Is it possible to snap a photo of that mod? I thought about modifying the upper crossmember but getting the upper shock mounts inwards a bit more to lose 1 or 1.5 in of ground clearance.
      Merritt Island,FL
      Here is a pic of the mod. I just cut out the existing crossmember and added my own round tube crossmember.It is pushed up against the floor.
      Florida
      Good looking build! I don't see any trim studs around the windshield opening. Are you using flush mounted glass?
      Merritt Island,FL
      Quote Originally Posted by NOT A TA View Post
      Thanks, No flush mounted glass, We will add the studs later, replacement parts don't come with them.
      Merritt Island,FL
      We got the rearend and suspension in the Firebird today. The rear is sitting several inches higher than ride height because there is not weight in the car.
      Apr 2004
      Cedar Rapids, IA
      pretty sweet!
      Merritt Island,FL
      Here are some current pictures of the project. Project is currently back home with the customer awaiting drive train.
