      Jul 2012
      Mooresville, NC
      Custom Gas Tank Issues - 1969 camaro
      I had a custom gas tank made by a local hotrod shop for my '69 camaro. The tanks is basically identical to the narrowed stainless steel gas tanks manufactured by DSE. The problem I have is that when I fill it with fuel and drive the car for a period of time, the tank wants to pressurize and burp fuel through the vent line. The vent line for the tank is integrated into the fuel pump bracket which is recessed into the tank. Its obvious to me that with the current configuration I will not be able to fill the tank to its maximum capacity. I am assuming since the car has a slight rakeflush to the trunk pan....when it is full there is an air pocket that develops mid way of the tank towards the filler neck. The gas cap has a check valve, but it is to prevent the tank from pulling a vacuum....not building pressure. I thought about adding a second vent line off the filler neck. Anybody else had these issues? If so, how did you go about fixing it? Thanks team!!!!
      May 2002
      Northern California
      where is your existing vent line going to? open air or a can?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Jul 2012
      Mooresville, NC
      The vent is routed from the integrated barbed fitting at the fuel pump mounting bracket via a rubber hose to where my DSE shock tower box is located ~10" above tank level.
      I am thinking that since the fuel pump is recessed and when full the fluid level is above the vent line and pressure can build up around the filler neck. The car has a slight rake which can lead to the full being more prone to going toward the front of the tank (car rear end) where the fuel pump/vent is located. If pressure builds from mid tank to filler neck area when full it could actually push fluid up and out of the vent line I have installed. Even if I made the vent longer I don't think the tank will vent properly since there is a fluid level between the vent and air pocket. It almost seems that I need to add a vent around the filler neck area which may eliminate the problem?
      Nov 2011
      Virginia
      Pics would go a long way here...
      Jan 2013
      Las Vegas, NV
      Try running it with the cap off... if the problem goes away then you know your answer.
      Scott Atkinson
      68 Camaro SS in progress
      Las Vegas, NV / Redondo Beach, CA
      Oct 2010
      Sacramento, CA
      If you look at a modern filler neck you will see a vent line that goes from the top of the tank to the filler neck. I assume it is to get the air to the highest point. So when I had the same problem with my 69 camaro I put the vent in the filler neck too. Routed it up into the trunk and through a fuel filter, then back out to atmosphere.
      Rick
      Rick - 1969 Camaro - LS1 driven daily
      You're right that the vent port should normally be in air, but a submerged vent port will just push fluid out the vent line to relieve pressure. Gasoline in and of itself won't allow the tank to pressurize. If your tank is developing pressure (do you hear a "whoosh" of air when you open the cap?), then your vent line is plugged or inoperable in some way.
      The best way to vent your tank is by using a properly designed vent system: tank vent port at a high point in the tank, plumbed to a vapor trap and liquid reservoir that allows air to flow both in and out of the tank, and a modern sealed fuel cap. We can help.
      ​John Parsons
