      World Products 427 Short Block Compression Ratio
      Thinking of buying the 427 short block assembly from World Products. They have two different version, one with a dome piston, the other with a dished piston. The dished unit allegedly makes about 9.5:1 compression with their 220 Motown heads.
      What about the bigger piston piece? I have 67 cc chambers on the Brodix heads that will go on the motor. Does anyone know how high the compression will be with the dome pistons? I fear too high for a pump gas/race gas mix, but can't seem to find the specific numbers.
      Gracias,
      Mark
      Nov 2003
      Maine
      mark
      entered some numbers in compression ratio calc, got dome size from worlds website, they offer a 10 cc dome and a -20cc dish, using your 67 cc heads, the 10 cc dome would be 14.1074-1, too much, the -20 cc dish would come in at 10.0465-1,still alittle light i would be 10.75-1 or higher
      tony at afr says to push 11-1 out of cast block, alum head motors, and he lives in the land of 91 octane too
      jake
      That's what I thought, thanks dude. Too damn high, for certain.
      Hmmmm.
      Nov 2003
      Maine
      heads
      mark use the -20 cc and have heads milled down some to bump up to 10-5-1 or higher depending on how much can be taken off before piston to valve clearance , take as much as possible to get to 11-1 or so
      jake
      Aug 2003
      There are plenty of 5cc valve relief pistons around to be able to run right at 11 to 1. Without doing your math I know my 404 is 10.6 to 1 at 70CCs.
      I can hook you up with a discount on World stuff. let me know when you are ready to buy. The discount ain't a bunch, but it is a discount none the less.
      Thanks a million Frank (and Jake!!!), but it is starting to look like the path of least resistance, and cost, and most importantly time! is to go with a Dart based 406. Might not be as sexy for bench racing as a 427, but I just want a solid reliable motor, as soon as possible so I can whip the poopy out of my car (Willow Springs 9/22? doubt it, but maybe?). Like yesterday. I can get a block locally tomorrow, pistons are readily available off the shelf, rods and cranks too, so the only element left to take me hostage is a machine shop. And we all know "that" won't happen....
      Mark
      Nov 2003
      Maine
      frank
      mark sounds great, frank i was just going by using what came with in thw world short block, as you say, a new piston would be the way to go, but why look at a shortblock you have to change pistons in?? right, goodluck mark
      jake
