    Results 1 to 1 of 1
      Aug 2012
      Henderson, TN
      1968 Chevelle SS project
      I have here a 1968 Chevelle SS Yes it is a SS, Not a clone..was going to restore it but I decided to build a shop first.
      It is a 396 big block 4-SPd car but (has a auto trans now 350 turbo with a small stall and a shift kit)
      This car does not need no where near as much work as all the others you will find, you could have this car ready to go and not break the bank.
      The car is sanded down to bare metal and does NoT have much rust at all couple small spots around the rear wheel wells and a spot at the top of the back glass and that's pretty much it so you will NOT have to put quarter panels in it. And the floor pans are all good. The car has been kept in a garage the whole time.
      Original SS 138 car
      396 big block that runs! It has a small cam and headers. I can crank it easily and you can hear it run. All it needs to be driven is the drive shaft put in and the trans linkage hooked up and radiator and pulleys put on. But it is crankable like it sits
      Has the factory gauges with the rolling tach in the middle.
      All the nuts and bolts are pretty much labels in cans by where they go.
      I have all the parts to put the car back together except the factory bucket seats and the center console, But I do have some after market bucket seats that are brand new that will go with it. They are just dusty from sittin in my garage, And the factory rear seat is in pretty good condition just a lil wear at the top.i have all the trim pieces and interior and everything
      Also I have disc brakes for the front
      I even have extra part like extra distributor, gears and few more odd things.
      $9,500 obo
      I kno I probably forgot a lot so just call or text me with any questions
      Any questions please
      Call or text 1-731-608-1288
      Located in Henderson, TN
