      Nov 2009
      Austin Texas
      Anyone running e85?
      What tank/pump/lines are you running? Most likely the car will be run on 93 to get the bugs worked out but I would like to have the option to possibly switch to E85 and maybe forced induction in the future.
      Apr 2010
      Pittsburgh, PA
      I was planning too, but decided not to due to only having 2 maybe 3 gas stations,..and all are 20-30 mins away..
      But look into a Stainless steel tank
      What HP you running or plan to run
      you need bigger injectors for same HP as you would need for gas
      I specifically chose fuelab pump and their electronic FPR as they were compatible with all types of fuel, but may sell them as I want a vaporworks setup :-D
      72 buick skylark
      May 2011
      Chippewa Falls, WI
      I am running E85 all the time since it is readily available in the MN/WI area. It's also a turbo car so its a no brainer for high boost pump gas.
      I have a sumped stock tank, Magnafuel 4303 pump, teflon -10 feed -8 returns, 220lb injectors. Fuel system should be capable of 1200WHP or so on E85.
      Justin N.
      1966 Chevelle
      1992 GMC Typhoon
      1989 Jeep Wrangler CJ 6.0 Twin Turbo
      1981 Jeep CJ7
