    Results 1 to 9 of 9
    Thread: LS1 in A-body
      LS1 in A-body
      Hi everyone,
      I have a question for anyone that installed an LS1 in an A-body. I`m wondering about clearance for the AC compressor. I have a block sitting in the chassis right now and although I don`t have the compressor or brackets yet it sure looks like I might have to cut and modify the frame.
      Anyone have experience with this setup?
      Thanks for any input,
      Kurt
      www.autokraft.org
      Nov 2004
      NW Arkansas
      Haven't done it yet....but i'm sure it has been done! I should be putting mine in in the next couple weeks!
      KENNY DAVIS HOTRODS
      Jul 2002
      Mesquite, TX
      My understanding is that it depends on which style of engine mount brackets you use - the S&P style puts the engine back and low, which is great for CG and for room to add other stuff under the hood (like twins!) but will require the crossmember be notched; or the BRP style which raises the engine up and moves it forward so the compressor clears without issue.
      Red Deer, Alberta, Canada
      Quote Originally Posted by derekf
      For a 70-72 A-Body GM that is incorrect. S&P moves the engine forward. BRP puts the engine (passenger side head) 1/2-1/4inches from the firewall. The S&P and BRP are opposite from the Camaro's to Chevelle's.
      I'm using the BRP mounts... My passenger side head is 1/4inch from the firewall, and the front of the oil pan(thinnest part looking at it from the side) is resting on my front crossmember. S&P cuts about 2 inches into the thicker portion of the pan to move it forward those 2 or so inches.
      Edit: BRP is not a direct bolt in deal My tranny tunnel looks like a cheap hoochie mamma
      -Matt
      Matt
      Instagram: Cst_koon
      Jul 2002
      Mesquite, TX
      Thanks for the correction. I reckon that also applies to A bodies that are a little earlier than 70 (like maybe 69s?)
      I mocked up my block/pan/heads in the 65 last weekend just to see what kind of clearance I had and it looked like with the pass head ~1/2 from the firewall the crossmember cleared the oil pan just fine, but there was absolutely no room for the compressor and it looked like the pass side engine mount would interfere with putting the compressor in even with a notched frame.
      Derek,
      I believe both kits require the frame to be notched unless you bend over and buy S&P's A/C bracket...
      It must be 68-72 A-body's. But don't quote me, I haven't looked into the underhood designs of the 68-9's.
      -Matt
      Matt
      Instagram: Cst_koon
      AC is for wimps! :D
      Pittsboro, NC
      There is an article in Oct issue of CHP that has a 66-67 chevelle with a 98' LS1. I have not read the article yet, so I cant say exactly what mounts, brackets etc was used.
      Macon, Ga.
      In about two more weeks, I can give you the latest info on how the S and P stuff works in an early (65) A-body. Of course it is the expensive way to go, but the parts fit. So far so good, but all parts are not here yet. So far their oil pan fits nicely, the headers are close but fit, the collectors are being "modified". The brackets and pulleys are due in here anytime. Their engine mounting plates are a piece of art and fit as they said they would.
      Bill
      Trailers are for BOATS!
