    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 46 of 46
    Thread: CV Driveshaft
    1. #41
      Carson city NV
      Frank at the DriveShaft Shop told me the same thing about the rubber transmission mount and CV joints.
      What did frank actually say about using a rubber transmission mount with the CV joint?
      I have a CV joint driveshaft from the driveshaft shop never mentioned anything about rubber transmission mount
      Scott C
    2. #42
      Fredericksburg, VA.
      Quote Originally Posted by blacklab View Post
      Frank did not say anything about using a rubber trans mount with CV joints. What Frank did say was that the rubber trans mount might reduce the vibration and that I likely did not need CV joints.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
    3. #43
      Aug 2016
      Indiana
      Andrew,
      What has been your experience with thus drive shaft? I have a 70 chevelle with an ls motor 4l80e and the trans tail shaft sits 4* down. The pinion is at 0* so the drive shaft points up to the pinion. I have a vibration at high torque. I am running 850 hp so my question is will the cv joint hold up under this type of hp.
    4. #44
      May 2010
      kitchener,Ontario,Canada
      There's lots of high hp Porsche's
      Ryan Austin
      On Instagram ryanaustinss70
    5. #45
      Quote Originally Posted by Terryjr View Post
      Andrew,
      My car doesn't make enough power to really stress this type of driveshaft. However, my buddy TJ runs one in his Chevelle....
      TJ uses an aluminum shaft and so far no issues. The car is 3590 pounds, runs 9.60s @ 140 mph and pulls 1.4x 60 foot times...
    6. #46
      Apr 2014
      JAPAN
      Country Flag: Japan
      I want my 1970 Camaro to stop vibrating. I'm thinking about the pinion angle, but I'm also thinking about the shaft problem. There is a limit to the thickness of the shaft due to the rear suspension equipped with a speed tech torque arm. I need your advice.
Size:  440.7 KBName:  IMG_0440.jpg
Size:  477.9 KBName:  IMG_8456.jpg
