    Results 41 to 60 of 67
    1. #41
      Benicia, Ca.
      Price range of these?
      PM on the way.
      Matt
      MCB - Matt's Classic Bowties
      5360 Gateway Plaza Dr.
      Benicia, Ca. 94510
      866-628-8746
      TEXT ONLY: 925-989-9091 (Replied 8-4)
      www.mcbparts.com
      Email: [email protected]
      Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
      Hours: Monday to Friday 8am - 4pm Pacific
      We ALWAYS enjoy talking to our customers!
      We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
    2. #42
      Jun 2006
      Just a heads up here guys, I just took delivery of my system and am fitting it to the car right now! Beyond excited about it! Big thanks to MCB and Jake at Vi-King for helping me out here!!
      Steve - I am very interested in seeing what the kit consists of and how it is integrated.
      -Michael
    3. #43
      May 2015
      Island Lake, IL
      Just found this thread. These electronic shocks look interesting.
      All I need is AME IRS and these shocks...that was pretty funny.
    4. #44
      Benicia, Ca.
      Maybe steve can post some shots of what he got but basically what you get is the 4 coil overs, 4 sensors to go at each wheel, a central computer and wiring to connect it together. It's a pretty basic install.
      We are a direct AME distributor as well, we can put together a package for you, just let me know.
      Matt
      Benicia, Ca. 94510
      866-628-8746
      www.mcbparts.com
    5. #45
      Jun 2006
      Quote Originally Posted by MCB Matt View Post
      Matt
      Not interested in AME, just the Viking Beserker System. I have not seen any technical information on the system beyond the Sema videos. Each corner has a controller w/ accelerometer and what looks like a rotary position sensor. It sounds like the chassis controller has a multi-axis accelerometer to get pitch and roll info. They state that it has a steering position sensor, I'm curious how that is executed. I would like to know cost for the system and what modifications are needed.
    6. #46
      Nov 2009
      the dirty mitten
      Here is my rear shock setup going into the car, obviously I have a non-standard thing going on here but I will be happy to post the kit and everything that I got. I installed the shocks without the springs because you need to be able to cycle the suspension thru its range of motion so that the central computer knows the limits of its available travel reading that thru the wheel travel sensors that you can see here. The computer will tighten up the valving near the ends of travel and lock it out before doing any kind of damage. I will put up a pic of the steering wheel position sensor but that is essentially a toothed wheel that clamps onto the steering shaft after the column and a clamp that mounts the sensor off of the end of the column
      Also pretty cool that the system comes with a thumb drive with info and VERY detailed install instructions
      Steve
    7. #47
      Jun 2006
      Thanks Steve. I am interested in seeing how you tackle the wheel position sensor install. Overall sounds pretty cool. I really love the idea of putting this system on my car.
      -Michael
    8. #48
      Benicia, Ca.
      Steve pretty much covered the main systems. The install itself is not highly complicated. PM for some pricing and we can discuss the system further.
      Matt
      Benicia, Ca. 94510
      866-628-8746
      www.mcbparts.com
    9. #49
      Nov 2009
      the dirty mitten
      Michael, because of my push rod systems my install is slightly different but not too much. You still would mount the sensors on your frame somewhere and the other end on a control arm. Just need to keep in mind they only can safely have a 2.75 inch sweep. The instructions include a template to check its travel and also a good formula to calculate where the mounts should go. You can see how I mounted the rear sensors in the above pic, here are the fronts done, pretty much the same idea
      Here is the steering position sensor as well as one of the wheel position sensors. You can see the clamp the mounts to a stationary place (most likely the steering column), the sensor that keys into the mount and it's depth is adjusted with the nuts then the toothed wheel that mounts to the steering shaft, it has a 1 inch inside diameter. There is no center tooth or anything on that, the system will determine when the steering in straight based on what it see's the position is most of the time.
      Each corner requires the shock (keep in mind that they are also offered in remote reservoir), a wheel position sensor and corner computer. The computer plugs into the sensor and shock, then a 4 wire cable connects to the central computer. The central computer will also require a vehicle speed sensor signal.
      Also notable is that you can have the orientation of either your piggy-back reservoir or remote reservoir specified. My rear shocks have the piggy-back parallel to the shock mounting bolt, my fronts have the reservoir perpendicular each for packaging reasons.
      one of the 4 wheel computers
      Also included in the kit is thrust bearings for each shock (allow the springs to twist and they cycle), spanner wrenches to adjust the perches, rod ends, nuts, bolts and all thread for the wheel position sensors, an indicator LED, 3 position rocker switch for the street/track/race selection and plenty of wiring and a relay to get it all done.
      Their online catalog has plenty of good info on this kit as well. Also the guys at Vi-King are awesome, very knowledgable and helpful. They helped me pick my spring rates which are actually only 200# front and 150# rear. They recommended using such a soft spring because the shock system is so good and can do the work much better than way
      Edit: from their catalog showing all that is included
      Steve
    10. #50
      Waterloo, Ia
      So out of curiosity....how much are these?
      -Nick
      -1967 GTO I drive and race
      -Build threads:
    11. #51
      May 2015
      Island Lake, IL
      Quote Originally Posted by Nicks67GTO View Post
      Catalog is listing $5500
    12. #52
      Nov 2009
      the dirty mitten
      Get a price quote from MCB, they will be more than happy to help you out. Matt is really excited about this kit
      Steve
    13. #53
      Jun 2006
      Nice. Finding a location on the front off the control arm should be do-able. Rear will be more of a challenge, I will have to do something off the rear spring mount or rear sway bar. If I can't manage less than 2.75" why not make the arm longer? It is just rotary is it not?
      I have an Ididit column, this should be pretty easy.
      I would probably have to do the remote reservoirs to make them work in my car without too many mods. I wonder if the lines to the reservoirs are long enough for me to put them behind the factory splash shields. Rear shocks would be easy, just put them in the trunk above the axle.
      Spring rates are all relative, depends on your motion ratio. I have the "factory" style torsion bars, A-body, 1.12" which results in about a 300# wheel rate. That is not soft, but not terribly stiff either. Rear leafs are 200#. When the time comes I will talk to the Vi-king guys and get it sorted out. Swapping torsion bars and springs is cheap relative to the price of this system.
    14. #54
      Nov 2009
      the dirty mitten
      Looking over the wiring diagram again it does not show that a speed sensor is required. The master control unit has a spot for the wiring tho so I will have to talk to vi-king about this.
      No doubt that if necessary you could increase the length of the arms on the wheel sensors. They have 3 holes on them now so you can just bolt an extension on to that.
      I am not sure the length of the lines on the remote reservoir setup but in pictures in the install manual, they show it all assembled just the way you describe. Lines thru the inner fender and the assembly located inside the engine bay
      Steve
    15. #55
      Jun 2006
      I would assume the VSS output of my T-56 Magnum would work. I would also assume the impedance is high enough on the input that I can use the same feed to send a signal to the EFI controller and the ASM controller.
    16. #56
      Nov 2011
      College Station, TX
      Quote Originally Posted by 68Cuda440 View Post
      Many GM OEM computers have a VSS output on them that you could probably tap into.
      Central TEXAS Sleeper
      Experimental Physicist
      '64 Riviera T-type: 4.1L Buick Turbo6, 4L80E, L67 OBDII SEFI swap
      ROA# 9790
    17. #57
      Benicia, Ca.
      Yes, you should be able to use the VSS output from the ECM. Otherwise, there are other options that many are running now like Dakota Digital or Autometers GPS speedo sender modules.
      Sorry I haven't been able to post much data, Kim and I are out of the country on vacay with the kids for the holidays. We will be back in next week. Our crew is in the office all week though. PM me for a price on a kit, I have a limited amount I am giving a little extra love on!
      Audios
      Matt + Kim
      Benicia, Ca. 94510
      866-628-8746
      www.mcbparts.com
    18. #58
      Nov 2009
      the dirty mitten
      Clarification from Vi-King about the VSS, at this time it is not needed and more oriented for drag racing, if there is an update that can make use of a speed sensor, my system will be updated and I can connect one at that time
      Steve
    19. #59
      Nov 2009
      the dirty mitten
      To finish up the system install on my car, the steering position sensor was last. Here is the toothed wheel installed on the steering shaft
      Because of the taper on the end of my column, I had to mount the sensor bracket further back then extend the bracket by 2 inches
      After that then I just had to adjust the sensor to be a certain distance from the wheel without making contact. I'm still adjusting some things on the system with the very easy to use computer program for this system, really looking forward to putting this thing thru its paces
      Steve
    20. #60
      Benicia, Ca.
      Wow Steve, you aren't wasting any time on your install! It's nice to see you are getting everything in already! Keep us posted as you progress.
      Happy New Year to everyone and feel free to PM or call to discuss a system for your car, this is obviously the most advanced suspension system available for our muscle cars to date! Very exciting product!
      Matt
      Benicia, Ca. 94510
      866-628-8746
      www.mcbparts.com
