    Results 1 to 20 of 23
      Las Vegas, NV
      Remember also, you mentioned "east coast" engines?? Alot of them , both iron and aluminum will have a fair amount of corrosion
      You didn't say where you are located?
      Yes, you will pay more for the "aluminum" block, but as you said earlier, this is for a daily driver/ cruiser, so please don't get hung up on this BS on 70-80 lbs heavier, you will never notice the difference, except from your wallet!!
      Try to stay away fro the larger 4L80E trans, for a daily driver, not making a ton of hp, it is a waste of $$
      larger, uses more hp to operate, and may have clearance/ tunnel fitment issues in your car ?? etc
      the 4L60E will work great for you and will fit better
      Are you planning on having a stock harness modified to standalone? or going to a aftermarket one? (keep in mind that the factory truck harnesses exit off the drivers front of engine, just behind the alternator, compared to car, exits off back of intake manifold, so a bit of planning when deciding the placement of your pcm, the truck harnesses "modified" don't have a clean appearance like the car setups
