    Results 1 to 12 of 12
      Jun 2010
      Arroyo Grande, Ca
      Steering Question
      so i currently have 12:1 gear box in my 66 El Camino, when i am autocrossing it on the turn arounds my arms are all crossed up so i made a call to Lee and they can change the 12:1 to a 9:1 but...they said it will be twitchy
      anybody out there running with a 9:1?
      Beach Park IL
      Shuffle steer......seriously.
      Bryce is running 8:1 I believe with a circle track quickener. Shorter steering arms are another option.
      Donny
      Jun 2010
      Arroyo Grande, Ca
      bryce with the Corvette? and what is Shuffle Steer?
      Jun 2010
      Arroyo Grande, Ca
      I goggled it wow....very interesting
      Lawrenceburg, TN
      yep
      I bet 99% of the cars at the track, not at home on jack stands, are 12:1, also depends on steering wheel size, I use a 15 wheel its larger than most but the steering input smoother has a larger area to shuffle and I steer using body and shoulders instead of the forearms and for me that reduces fatigue
      Jun 2010
      Arroyo Grande, Ca
      yep
      I think i will stay with the 12:1 but Lee said they will match my pump to the 12:1 and it will be better
      Beach Park IL
      Quote Originally Posted by surfwagon View Post
      Bryce with the falcon...."project blueprint"
      Strano is the only guy I have seen effectively rarely let go of the wheel. Watch his youtube videos.....I think his arms are made of rubber.
      Right or wrong, I have stopped holding the wheel so tight. I sort of "cup it" and guide the wheel instead of trying to force my will on it. I try to drive just below 9 and 3 and for a tight turn that will require more input than usual I will slide a hand up to the top and then guide the wheel as it unwinds.
      Donny
      Lawrenceburg, TN
      you can see my hand shuffle on the vid, this was with testing a 13inch steering wheel
      san diego
      I run 8:1 manual steering in my falcon and I love it. I just added power steering and neither were twitchy and great on the track. I run a little toe out which can pick up the expansion grooves on the freeway.
      san diego
      yep
      my car does spend a lot of time at home, sometimes on jack stands.
      Lawrenceburg, TN
      Quote Originally Posted by Bryce View Post
      ha ha ha.... your funny Bryce!
      Lawrenceburg, TN
      I don't think 8:1 would be "twitchy" like Bryce says it really depends on the alignment settings and steering wheel size is used I would use a 14 or 15 inch wheel that smooths out the inputs, I personally look for a ratio to response of 1-1, on steering, throttle, brakes and clutch for my car
