Thread: 69 Camaro hydroboost Q
01-01-2014 #1
- Feb 2007
- ALABAMA
- 147
Searched but can't find what I'm looking for.
Original front disc /rear drum car now has LS disc on rear.
I have an astro hydro set-up with recommended vette MC. I still have the factory style lines for the disc/drum combo. Will these lines still work? Does the block on the rear brake line, on the frame near driver seat, need to change? What proportional valve do I need to run? Do I need one? Thanks for the continued help.
Chad
01-03-2014 #2If the "recommended" MC is from a late 60's Corvette then your existing lines should be ok.
Here's what I did:
Used the factory distribution block with a shortened bracket to mount it.
Did away with the metering valve (the round one at the MC) and plumbed a line from the front port on the MC to the front of the dist block
Did away with the factory frame mounted prop valve and installed an adjustable prop valve in its place. I had to shorten and reflare one line to get the valve to fit - your mileage might vary.
01-03-2014 #3
- May 2011
- Chippewa Falls, WI
- 290
