    Results 1 to 19 of 19
      Dec 2012
      Edinburg Tx
      Nine inch diff. For road course?
      What kind off unit are you running in your ford 9inch , and how much rwhp? Im ready to swap out my spool for a unit but need something that will hold hard launches (drag slicks) for 1/4 mile drag racing . So pretty much my question what unit to run for both road race and drag race?
      Thanks.
      Mar 2013
      Beaufort,SC
      how about a wavetrac? Or a detroit locker?
      Feb 2008
      Texas
      Strange s trac and their new hd aluminum case. I don't have a 9in rear or anything, but it's what I would get if had the money.
      http://ls1tech.com/forums/gears-axle...inch-case.html
      http://ls1tech.com/forums/gears-axle...ge-s-trac.html
      http://www.youtube.com/user/cutlassrkt?feature=mhee
      69 cutlass - 5.3l L33, Jakes stage 3 4L80e, 275/40/17 proxes tq
      There are lots of threads on this exact subject. For some context, nuance, and various arguments do a search. My recommendation: Detroit Locker 33 or 35 spline.
      ​John Parsons
      Dec 2012
      Edinburg Tx
      Strange s trac looks good , i had a detroit locker before but hated the way it locked every time i would stop and go.
      Jul 2013
      Hubert, NC
      430 H.P with TracLoc
      David H. Amrine
      (USMC Retired)
      Boys drive fast on the street. But MEN prove how fast they are at the Track.
      Wake Forest,NC
      520 rwhp I'm using a C&R Racing built Strange/Ford racing case, Tru-trac, internal cooling pump, and rem finished gears. I was told to not use an aluminum case for a road course car due to the heat build up on a road course. The Strange case is cast steel and considerably lighter than the nodular iron ones.
      Quote Originally Posted by 71RS/SS396 View Post
      The density of iron and steel is identical. So unless Strange heavily machined the steel carrier, I can't imagine that it would be "considerably" lighter than iron. Even if it was heavily machined, I can't imagine that the difference in weight is more than a couple of pounds. Just saying…
      Mar 2011
      Ca
      I have just under 550 hp using 35 spline axles and a Detroit locker.
      Wake Forest,NC
      It's thinner than the iron case. I've never weighed the two to compare but you can definitely tell the difference when you lift them, maybe I'll weigh them since you seem to be doubting the fact it's lighter.
      Feb 2008
      Denver NC
      Do you have the Ford SVT investment cast steel case? Them things are super nice... I'd say they are at least 8-10 pounds lighter than a nodular
      Need A T-101,Jerico or other 4 speed transmission serviced? Pm me....
      Wake Forest,NC
      Quote Originally Posted by HarleyR View Post
      Yes, it has the Ford racing logo on it. I was told by C&R that it's the same 3rd member that Nascar uses without the $3000 X-trac gears, I didn't see the need for those.
      Feb 2008
      Denver NC
      Yes that's what the cup cars are allowed to run they are illegal in nationwide and trucks... They are nice pieces without a doubt.. The guys at C&R are great to work with... Known them
      For a few years...
      Dec 2011
      Chicago, IL.
      I had to check this out, so I took a walk out to the shop. The Ford Motorsport case we machine for them is 20.1 Lbs. and our Nodular case is 30.5 Lbs. That is as much as they will let me share.
      Wil.
      Strange Engineering/Zange's Martial Arts
      Wake Forest,NC
      Quote Originally Posted by AmKenpo1 View Post
      Wil.
      Thanks for the info Wil, you saved me the trouble of weighing it to share with Andrew.
      Nov 2013
      Elora Ontario
      I run a cup case with a locker and street gears. Car makes 470 hp. To the tires and has run 12.80's @ 108 in the quarter.
      1967 Mustang Fastback pro-touring, 1964 Falcon 347- 76mm a/w turbo, 1957 meteor Rideau 500 Gasser, 1979 F250 4X4
      1966 Mustang Fastback twin turbo 4v mod motor.
      Something you might want to consider is an OLD Ford 8 Inch Rear-end.
      I know a lot of guys running the 8 inch rear in Shelby and Ford Mustang Full ROAD Race prepared cars running 450HP-500HP race engines with Toploader transmissions and 5 Speeds with no problems at all. Yes they are running a good center section and good axles. Certainly not the setup for drag racing however the loads on the rear-end is different road racing.
      The 8 inch rear-end is MUCH lighter and has proven hard to tear up road racing. Also somewhat cheaper to build and certainly much to cheaper to buy on the front-end.
      Something to consider?
      Bigger, Badder, Heavier and more expensive is NOT always better or needed!
      Mike
      www.musclecardeals.com
      Dec 2012
      Edinburg Tx
      Lot if good info thanks guys . Setup I'm going with will be in the four digit rwhp . I will try the s trac that comes with lifetime warranty .
      Nov 2009
      the dirty mitten
      I had always been planning to run a bolt thru aluminum 3rd, 450hp and AWD so not all the power to the rear. Is there a super strong case against it that would sway me to nodular or something?
      Steve
