    Thread: 350 olds
      Jan 2013
      350 olds
      I need some advise I'm about to upgrade my transmission and I want to know what should I go with I'm looking at the 2004r are the 4l60e with electronic shifter I'm look to do the power tour next year here is my spec on my engine thanks for your feed back
      Cam Style:Hydraulic flat tappet
      Basic Operating RPM Range:1,800-6,000
      Intake Duration at 050 inch Lift:230
      Exhaust Duration at 050 inch Lift:236
      Duration at 050 inch Lift:230 int./236 exh.
      Advertised Intake Duration:274
      Advertised Exhaust Duration:286
      Advertised Duration:274 int./286 exh.
      Intake Valve Lift with Factory Rocker Arm Ratio:0.520 in.
      Exhaust Valve Lift with Factory Rocker Arm Ratio:0.523 in.
      Valve Lift with Factory Rocker Arm Ratio:0.520 int./0.523 exh.
      Lobe Separation (degrees):110
      Grind Number:OL XE274H-10
      Computer-Controlled Compatible:No
      Lifters Included:Yes
      Lifter Style:Hydraulic flat tappet
      CCA-1441-KIT rocker arm kits
      Rocker Arm Mounting Style:Stud
      Rocker Arm Ratio:1.6
      Rocker Arm Style:Roller tip
      Stud Size:3/8 in.
      Shims Included:No
      Rocker Arm Material:Steel
      Self-Aligning:No
      Rocker Arm Body Style:Standard
      Rocker Arm Nut Style:Self-locking
      Slot Style:Long
      Maximum Spring Diameter (in):1.500 in.
      HRS-98411 valve springs
      Number of Springs Per Valve:Single
      Outside Diameter of Outer Spring (in):1.437 in.
      Coil Bind Height (in):1.050 in.
      Damper Spring Included:Yes
      Spring Rate (lbs/in):246 lbs./in.
      Inside Diameter of Inner Spring (in):0.960 in.
      SLP-L2320F pistons
      Bore (in):4.057 in.
      Bore (mm):103.048mm
      Piston Style:Flat top, with no valve reliefs
      Piston Material:Forged aluminum
      Compression Distance (in):1.612 in.
      Wrist Pin Style:Press-fit
      Pin Diameter (in):0.980 in.
      Piston Ring Thickness:5/64 in. x 5/64 in. x 3/16 in.
      HOK-3901-1HKR headers
      Header Style:Full-length
      Header Material:Steel
      Header Finish:Silver ceramic coated
      Weld-Up:No
      Primary Tube Diameter (in):1 5/8 in.
      Collector Attachment:3-bolt flange
      Collector Diameter:2.500 in.
      Tuned:No
      Primary Tube Length (in):29 in.
      Primary Tube Gauge:16-gauge
      Feb 2009
      Laramie, WY
      The 200r4 would be a bolt on. A lot of the Buick guys are doing it because of that fact. where as the 4l60 would need an adapter and the computer BS. Nice ride though.
      Tim
      1971 Buick Sportwagon pro-touring project. Buick 455 TH350, SPC front suspension, UMI rear suspension, KYB shocks, Slowly getting there.
      1985 Ford Crown Victoria 2 door next project.
      Cornettsville, ky
      what he said plus a 200 is stronger if you build them and has more od. the 60e will also require a shortened driveshaft. the 200 bolts right into place of the 200.
      Apr 2010
      Pittsburgh, PA
      I'd go 2004 as its practically bolt in..has better gear split and stronger
      Fully built should be about 1800 through Janis transmissions..think this was with non lockup converter.
      If you can swing it a 4l80e would be nice and bullet proof..but more cash
      72 buick skylark
