    Results 1 to 11 of 11
      Mar 2010
      Jacksonville FL.
      Dry Sumps? Anybody Running One?
      Hey Guys,
      I'm starting on my '66 Mustang Fastback build. The other day, I ran across a smokin' deal on a Roush Yates NASCAR engine... I couldn't pass it up!!
      Now, I'm looking for any information I can get on installing the dry sump system. Any experience, photos or input would be greatly appreciated.
      Nov 2009
      the dirty mitten
      I am currently building my own dry sump system, nice score on that engine! I'd assume that it has an oil pan already and lines. If so then all you really need is a tank and a new belt. Dry sumps are the best possible oiling system and actually add HP because of the extra vacuum inside the block (allows the pieces to move around thru the air easier).
      Steve
      Mar 2010
      Jacksonville FL.
      Yes, the pan is on the engine but the only lines are what's comming off the pump in the photo. I'll get a tank with it but he said it's the tank they run in the NASCAR's so it won't fit in the my car.
      Any photos of your build?
      Jun 2009
      Tiffin Oh
      I run all Peterson stuff call them they are great to work with.
      Nov 2013
      Country Flag: South Africa
      Hi, try these guys:- http://aviaid.com/ they have all the goodies for a dry sump system and diagrams of how to do all the plumbing etc.
      Sep 2008
      Jacksonville, Florida
      Your going to have to find out who's pump your running. The lobe rotor scavenge sections will pull the most vacuum. You'll need to change the pulley ratio's for the desired RPM and for what pump sections you have. I run a Dailey pump with Peterson accessories, tank, filters, vacuum regulator, blow off, etc... Bill Dailey is extremely helpful and can setup your pulley ratios for you, as well as advise plumbing.
      Craig Scholl
      CJD Automotive, LLC
      904-400-1802
      www.cjdautomotive.com
      "I own a Mopar, I already know it won't be in stock, won't ship tomorrow, and won't fit without modification."
      Mar 2010
      Jacksonville FL.
      Quote Originally Posted by sccacuda View Post
      Good information, I wouldn't have know that, thank you.... I see your from Jax? I live in Callahan....
      Sep 2008
      Quote Originally Posted by manOwar View Post
      Well that's pretty dang close. Your welcome to come over to the shop and look at the dry sump setup and parts needed.
      Shop address is 2016 Imeson Rd, 32220.
      Craig Scholl
      CJD Automotive, LLC
      904-400-1802
      Mar 2010
      Jacksonville FL.
      I'll do that for sure! Thank you,
      Jim
      Nov 2009
      the dirty mitten
      So far I only have my oil pan made up but no fittings on it yet. I also have a 6 stage Auto Verdi pump that I will soon begin working on the mount for. You can google dry sump systems and there are a lot of good images to show the layout. For the gears a general rule of thumb is that you have the pump run at half speed of the crank however a street car may want it to spin faster because you are not turning high rpm. The pressure stage of the pump should have an adjuster on it so you can tune in your oil pressure
      this is my pump
      Steve
      oshawa ontario
      some day I'll be running one
      89 Iroc 406 Fitech 5 spd
      31 Scarab 2 x 454
