    Results 1 to 15 of 15
      Jan 2009
      DSE Brake Booster & Master Cylinder Problems
      To All,
      Just bought & installed the DSE Booster / Master Cylinder combo Part Number 050102. I have an LSX motor with new brake lines, rear brakes (Right Stuff Disc Brakes) and stock from brakes connected to a Summit Proportion Valve.
      The system has been bleed several times & "appears" to have no air in the lines. The pedal seems soft & even though the brakes catch, the pedal still goes further down when the car is stopped. Stopping distance seems to take too long. The pedal is harder when car is off & softer upon start-up.
      I have enlarged firewall opening to make sure boot is not snagging.
      Are the master cylinder ports designated to the front / rear or is this indifferent?
      I have 12" of vacuum at the booster.
      Could my rear brakes be a problem, someone has suggested plugging rears & seeing if improvements are made. Hate to have to get new brakes if these "Seville type calipers" are not cooperating.
      Any suggestions would be greatly appreciated.
      Regards,
      Thomas
