      Suisun City, Ca.
      Dynamat installation
      Well my little helper and I installed the dynamat over the weekend. I need another box to finish.
      Mike
      Mar 2003
      Make it big
      Looking good
      -David
      SoCal
      Hey, looks like that guy does good work... is he for hire??
      How much did you use?
      On my 67 Camaro I did the roof and firewall/cowl with two tri packs (12 sq ft each). The roof isn't covered completely. There's about 2 inches along both sides of the roof that aren't covered. Before the dynamat the roof rang like a bell when you tap it with your knuckle, now there's just a thud. As for the firewall/cowl, I covered from right behind the windshield molding down to the flat ledge on the passenger side and then down to the floor on the driver's side.
      I still have the bulk pak that I haven't opened yet. Do you think it will cover the floor and tunnel up to where I mentioned?
      Bedford TX
      I bet he's a good helper you just have to make sure he doesnt drool on the adhesive!
      Justin, 68 Camaro Update:5 speed is in and neighbors are pissed!
      Suisun City, Ca.
      black67ls1
      I use the bulk pac and went from where the firewall meets the cowl to the rear seat foot wells. If you have the firewall partial done, just a guess but your bulk pac should get you to the floor under the rear seat.
      Mike
