      Jan 2010
      Hellwig Sway Bar and SpeedTech Lower Control Arm
      Hey guys, I have SpeedTech lower control arms and just bought a Hellwig tubular swaybar(part# 55705) for my 67 camaro. I noticed that the bar ends aren't parallel with the lower control arm hole. The hole in the control arm and the hole in the sway bar are about an 1 in off. When installed the end links will be at an angle about 15 degrees. I'm not sure if all after market bars are like this. I roughly compared the Hellwig bar against a factory one and they appear to be bent and are the same length. It looks like the SpeedTech control arms have the hole for the end link about an 1 in. back than a factory control arm. This is with no load on the suspension. I have another frame with a factory sway bar and factory control arms and the end links are straight up and down.
      Thanks,Name:  FrontSwayBar.jpg
      corona,ca.
      Have you checked the sb hole to the lca hole with the endlink removed?you might need to shorten the endlink,i had to when i installed my hellwig sb on the chevelle.
      72 chevelle.
      Jul 2013
      St. George, UT
      Hey Tony, sorry we missed this. Did you get it squared away? It is slightly offset because these are tubular arms and the mounting hole is in the plate between the tubes, whereas the stamped factory lowers run the hole in the outer shoulder of the arm. Typically with the length of the first gen lowers (or any arm for that matter) in full droop it will move the location of that mount hole a bit. Having them in droop compounds the angle of everything. It should straighten out more when you get the car on the ground and everything will work/ function fine. Good luck!
