    Results 1 to 10 of 10
      Jan 2013
      Abbotsford, B.C.
      FS: Sweet mfg Power Steering Pump GM Type II
      Sold! Thanks GRNOVA!
      Jan 2013
      Abbotsford, B.C.
      Ttt
      Aug 2011
      North Platte,NE
      Is the shaft .664?
      Jan 2013
      Abbotsford, B.C.
      Yes it is .664
      Jan 2013
      Abbotsford, B.C.
      Ttt
      Do you know if its for remote tank or for the pump mounted tank? Do you know if it will work with a Hydra boot brake system??
      Jan 2013
      Abbotsford, B.C.
      Not sure if it will work with a hydraboost system, my guess it depends on the psi of the pump this one is rated for 1000psi and 3gpm.
      It is setup for a remote tank, I do have a pump mounted tank that I can include for an extra charge, but I have no idea if it can be adapted over.
      Jan 2013
      Abbotsford, B.C.
      TTT Lowered price
      Crown Point, Indiana
      do you know if it has a bearing or a bushing on the shaft? if it has a bearing i will take it!
