Results 1 to 12 of 12
- Oct 2006
- Chicago
- 297
Driveline Angle Issues on Lowered Car
First off, thanks for opening this thread and reading, since there are million topics on this already. I've read a good portion of them and understand the basics, but have a few questions for my situation I haven't seen explicitly answered.
My Olds G-body is lowered close to 2" all around. With some new rear adjustable control arms, I decided it was time to check driveline angles. I had checked them years ago, but realized I made a mistake of using the trans pan rail for the engine/trans measurement... and that doesn't correspond to the flexplate/starter block/front crank pulley measurement.
Right now, my rear end yoke is at 0*. The driveshaft runs uphill from the pinion yoke to the transmission tail shaft at 1.5*. My engine/transmission angle is 3.5*, with the tailshaft as the low point. Therefore, I have 1.5* of angle in the rear, and I have 2.0* of angle in the front.
Seems like it's spot on... however, the issue I have is that the driveshaft is at a shallower angle than the engine/trans. The U-joint angles are not parallel, but are opposite in orientation. The current arrangement looks something like this (not to scale, just a crude Paint sketch):
Therefore, I have one of two solutions that can be pursued.
Option 1. Shim up the trans mount on the crossmember. I ran a few preliminary numbers with rough geometry, and it looks like I'll need a 1 - 1.25" spacer on the trans mount to correct this. That's a lot of spacer! With a 1.25" spacer, my engine angle will only be approximately 1.75*. How critical is engine angle to performance? I assume it helps with oil drainback, and obviously the carb/air cleaner angle could end up looking a bit funny. I also have a mechanical fan to contend with (for now) that I would prefer to keep out of the shroud. After I spaced it, I would make the pinion angle match the engine/trans angle.
Option 2. Make the pinion angle equal the engine/trans angle and don't touch the trans mount. However, at that point, the driveshaft will most likely be level or running "up" to the rear end. This is not desirable for pinion climb under acceleration, as the pinion will be nosed up to the driveshaft, rather than nosed down. Here's a picture from the Inland Empire Driveline showing the situation I am describing:
(Full document located here: www.iedls.com/asp/admin/getFile.asp?RID=10&TID=28&FN=PDF)
Inland Empire references this is good for "street rod" applications and smooth running, but I'm not sure it's desirable for a performance application.
Does anybody have experience with this situation, and what solutions worked for them? Did I miss any other options? For reference, this is an Olds V-8, 200-4R trans, and 8.5" rear end.
Thanks in advance for any help!
Luke
'63 Chevy II wagon - project
