Thread: wheel hop
09-04-2005 #1
- Sep 2004
- 72
wheel hop
Hey guys!!! I know this doesn't quite fit in here but I have a 62 Chevy Bel Air. I have recently boxed the upper and lower cont. arms and added poly bushings in the rear. If you guys arent familar with these cars the have 2 lower control arms with the bottom of the coil spring mounted them. One upper control arm just to the pass side of the rear end pumpkin facing straight ahead with a bolt on mount with shims for pinion angle, and a panard bar from the driverside of the frame to the pass sise of the axle housing. back in the day it was posible to get a 2nd upper cont. arm on the driverside of the axle housing so I added the arm and mounts from another car and boxed it as well. Anyway... right now I have NO posi and with street tires It wheel hops VERY VERY badly!!! And with slicks on its just ugly!!! I would think with all these mods it would be pretty solid. Any thoughts??? I have heard that some times air bags in the coils will fix this but I dont see how??? Oh and BTW, I drag race some and mostly beat on it on the street, and I run a smallblock with a 4-speed. Thanks guys!!!!
