    Results 1 to 9 of 9
      Aug 2013
      North Las Vegas
      Parts that play nice?
      I am about to pull the trigger on a significant purchase for my 1968 Camaro and would like to know if the parts I spent a lot of time researching play well together.
      Suspension:
      AFX tall spindle from Speed Tech
      SPC Upper Control Arms
      Right Stuff Lower Control Arms
      Hotchkis Sport Suspension anti-sway bar kit (w/ 3" drop leaf springs)
      QA1 Pro Coil-Overs w/ 550lb spring rating (front)
      QA1 Stocker Star Shocks TN703 (rear)
      Questions
      The lower control arms are about the most affordable LCA I can find. They are lower and have 4 degrees of positive camber. Will this negativly affect the suspension geometry that the tall spindles correct? I am a little worried about over correcting the poor suspension geometry.
      I am looking to purchase an LS2 iron block (LQ4). Is the coil-over spring rate correct for this application? The product description says that 550lbs is for a big block but I read that stiffer spring are the way to go and I thought it work due to the extra weight of the iron block.
