Thread: rear end swap question,
10-23-2013 #1
Hi guys, I'm planning on replacing my chevy 10 bolt rear end with a 9 inch rear end, I'm gonna use the brackets for ride tech 4 link in a camaro , now my question is , how to i buy the rear axle? I have seen new housings for 500$ in currie, but i don't have the money to buy everything separately .
I saw in craigslist somebody is selling a ford 9 from a torino complete for 350 , can this be ok , buy it grind off al brakets send it to currie to inspect and clean , but what about the bolt pattern is it going to be different that chevy ? Have anyone donde this before ?? Thanks
10-23-2013 #2
- Oct 2013
- 533
What are you plans for the car? A 9 bolt is really just needed for cars pushing 1000 hp if your 10 bolt is a 8.5 it's just as strong as a 12 bolt and can handle power really well I would save the headache of buying a 9 inch especially if you don't have the funds to buy one from currie complete because then it just because a swap fest
10-23-2013 #3
- Oct 2013
- 533
Be comes**
10-23-2013 #4
- Aug 2010
- Seattle area
- 360
It easier and cheaper to find a 8.5 Corporate 10 bolt. one out a 73-4 Nova will bolt right in. I have one in my 1979 Z-28 Camaro Pro-touring Car .with a 364 cubic inch 500 HP plus supercharged small chevy.with a super T-10 four speed. 9 inch Fords are expensive . Then there is all the modifications you will have to make.. Plus you can drive around until you can afford to upgrade it. I upgraded mine with a Moroso "Brute Strength : Center section ,New Chevy 3:42 gears,and 30 spline Moser Axles. I just like to over build stuff.You can go your own route. I just don`t like doing stuff twice.
10-25-2013 #5
