    Results 1 to 1 of 1
      Jul 2013
      Two Harbors, MN
      400 Mopar - Fresh performance long block
      Pump Gas Street Build:
      '76 400 Chrysler block - line hone'd w/ARP studs, CNC bore, square deck
      .030 KB pistons @ zero deck
      Recon'd Factory rods with ARP Bolts - full floating
      Factory forged crank
      Total Seal Rings
      ACL RACE Main and Rod Bearings
      Balanced and blueprinted rotating assembly - Internal Balance
      Factory heads - Fully Ported and polished, New SI stainless steel valves, Comp Cams springs, retainers, and locks. Posi Seals. Milled .030 to make 9.7 to 1 compression
      Felpro Gaskets
      Milodon Oil pan
      Comp Cams double roller timing set
      Comp Cams 3 bolt cam - XE274 solid flat tappet
      adv. 274/280 .050 236/242 lift .502/.511 LSA 110
      Proform Shaft rockers
      Comp Cams pushrods
      Included but not pictured is intake, exhaust, & valve cover gaskets, Oil pump housing, filter adaptor, crank pulley, Flywheel, misc factory fasteners
      Machined and Assembled @ Joe Mondello Racing Engines in Crossville, TN
      Contact Cody
      JMRE -931-459-2760
      With a good intake, carb, and headers this engine will make around 450HP on pump gas.
      $4500 as long block
      $7000 Finished out with Dyno Tuning - Bolt in ready
      You can pick up or will ship at buyers expense
Size:  184.1 KBName:  IMG_3981.jpg
Size:  174.2 KBName:  IMG_3982.jpg
Size:  190.5 KBName:  IMG_3983.jpg
      Time Attack 85 Oldsmobile Cutlass
      Instagram: @Asphalt_Gundam
      YouTube: Cody Smith Motorsports
