    Thread: Dome Light
      Nov 2010
      Dome Light
      I've finally got to the point where this annoys me and I want to get it fixed. I have a 1970 Chevelle and the dome light is always on (I currently have the bulb removed). I've manually depressed both door sensors. No luck turning it off. I've also replaced the headlight switch, for other unrelated issues. It's still on. Any suggestions to troubleshoot this?
      May 2010
      kitchener,Ontario,Canada
      Door sensor isn't grounding properly from what I understand that's almost always the cause and door pins are cheap, hit up year one for some new ones maybe 15$ for on replacements should get you on the way. Clearly it's not the bulb, or housing, or the power so it has to be the switch...the door pins are the grounds and the switches
      Best of luck Ryan Austin
