    Page 2 of 2 FirstFirst 1 2
    Results 21 to 30 of 30
    1. #21
      Indiana
      Quote Originally Posted by 71beast View Post
      Yea, my whole suspension was done last year, with the help of Mark from SC&C. I have SPC Uppers and Lowers, tall howe balljoints, SPC springs, single adjustable Varishocks, Hellwig protouring antiswaybars (rear is adjustable), outback I have UMI double adjustable uppers and tubular lowers with roto-joints. I also had rebuilt the front end using PST parts, and did the jeep cherokee steering box conversion.
      I guess its hard to explain whats happening, but at normal low speeds the steering is nice and heavy, but once I get up to around 55+ it feels light, which is why I'm thinking its an aero issue. The floaty aspect is more like with the quick ratio box when I try to stay straight and do a small correction its more major, if that makes sense. I think it's also because its tight, rather then all loosey goosey like the original. With the original steering box it would still feel light at high speeds, but at low speeds it felt light too, and it was super sloppy.
      Btw, I've loved your Chevelle for awhile, its one bad mother...... I actually think it fits the early Chevelle, and would totally do the same if mine was an early body style, my comment was more about if I put that on mine it would look just slapped on, ya know? This is why I'm having such a huge problem trying to figure out how to make mine fit my body, almost factory looking.
      I found that post like two days ago, and had been reading it. Reading has me has me worried about making the aero worse.
      BTW, hopefully I'll be able to catch you at 164mph when I'm done.
      Thanks for the compliments.
      It sounds like you have your suspension in order, but at 55+ mph you should still have a tight, sporty feel to the car considering the parts you installed. Did you replace the center link? On my El Camino I thought my steering box was worn out and I replaced it only to find there was no improvement. While doing some other under car work, my wife moved the steering wheel for me and I noticed the pitman arm moved a tad before anything else moved. Upon closer inspection, the stud on the center link was loose causing the rest of the linkage to lag behind the pitman arm, which gave the car a floaty feel.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
    2. #22
      Mar 2012
      New Jersey
      Yea, when I did the suspension and steering box upgrade I changed all the steering components using PST steering linkage kit. So the center link, tie rods, idler arm, and tie rod sleeves. Could there be a problem with my steering box or the power steering pump? Or I was just thinking could it be that the alignment is off. I had to put spacers for the springs in, but don't remember if I got it realigned to Marks specs. The car still feels sporty at high speeds, the steering feels light. Like I said its kinda hard to explain.
      Plus I took some new measurements, from the ground to the bottom of the bumper is 12", but front the ground to the bottom of the chassis is 7.5". If I were to make an air dam how much lower then the chassis do I want to go, or should I just even out the chassis and front bumper?
    3. #23
      Oct 2013
      H-Town, TX
      Just a suggestion but if you are looking for something to kind of mold as you go to figure out what you want- maybe start with a 70-72 GTO Judge front spoiler. Looks like it would bolt up relatively easy and would be the proper size. Then you can add or remove material as you go to see what you like. I would think you could mold plastic or sheet metal to the style you want and then just attach it to the GTO spoiler. Then paint it all black of course.
    4. #24
      May 2012
      I dont know how good you are with photo shop or with art but me owning the same year chevelle also having the same idea in my head has pondered your same question over and over again. You take pictures and print them out then draw right on the print outs. I have designed graphic paint jobs this way. Paper is always a good spot to start. Look at some older chevelle stock cars they will be more period specific for aero ideas. I have not taken the time to design one or make one yet not at that part of my build.
      John
      72 chevelle SS that really a 71 according to the vin
    5. #25
      Sep 2011
      So Cal
      Custom Chevelle Air Dam Help
      You can try the 69 Camaro splitter - that's what I'm running - some people like it, some people don't .... I think the front of your car is gonna lift until you stiffen up your suspension though
    6. #26
      Mar 2012
      New Jersey
      Thanks for the ideas gto and dj. Been working in it for awhile. Kinda getting where I want it, but have to make sure it's what I want before putting the work into molding it and spending all the cash for supplies.
      Sam, trust me it's not my suspension at all. If you read closer to the beginning of the thread I mention everything in my suspension. In fact it was completed with the help of Mark of SC&C. The front end lift happening is due to air pushing the front of the car up, due to having about 12" of clearance from the ground to the bottom of the front bumper.
      The problem with the camaro spoiler on a car as big as the chevelle is that it's not going to stop air going under the car, it's short and narrow. In order to be functional it needs to be like herbs I'm trying to figure out how to make it so it will blend in more with the 71 chevelle body style. This is why I'm looking into making one that fits and will work correctly for my size car.
    7. #27
      Mar 2012
      New Jersey
      Been a long time since I posted any updates. Before the massive amounts of snow hit NJ I was messing around with some foam core trying to get some idea how it will look. Here you can get an idea how low its going to be, in fact this is only about 4" down, and I might make it 6" or so.
      My general concept is going to be to create a shape similar to an upside down "Z", which will mount under the bumper to cover the opening, then about 3-4" backwards behind that the air dam will come straight down, and bend backwards to create a flat area which will have turnbuckles that will mount to the core support. The splitter itself will form a "V" shape to help direct air away from the car, and flat to stop the air from moving under the car. It will extend to the front of the fender, where the factory brace is located to help prevent the wheels from messing up the air flow.
      I bought some 2" pink insulation foam that I'm going to carve to shape, then make it out of fiberglass or carbon fiber. The flat underside will allow me to add a splitter when racing, or extend lower to block more air.
      What do you guys think? Oh, and keep in mind it's either going to be flat/semigloss black, or natural carbon fiber, so I think it should blend in/sorta disappear under the car.
      Temp Form:
      Temp Form:
      Rough Sketch:
      Name:  Airdam Sketch.jpg
      I just need to figure out the turnbuckles. I'm not sure if I can get away with light duty aluminum ones from McMaster-Carr, or if I would need heavy duty stainless ones, or it it would be better to use heim joint rod ends instead to allow some movement/flex.
    8. #28
      Jul 2011
      Nashville/ Tampa
      How did you come to the conclusion that it s air lifting your car up? It that were the case why does every other chevelle not have that problem? It seems unlikely that at 55 mph that is what is going on. Air simply flowing under the car isn't necessarily going to push it up anyway, if it did, wheelies would never get landed at the track and every car on the road would be flying into ditches.
      https://www.instagram.com/gen_v_lt1_chevelle/
      Do not buy anything from Frankie's Used Auto Parts. Ever.
      Chevelle ̶a̶l̶m̶o̶s̶t̶ ̶f̶i̶n̶i̶s̶h̶e̶d̶ L92/200-4r now Gen V LT1 and T56- https://ls1tech.com/forums/conversio...nvertible.html
    9. #29
      Mar 2012
      New Jersey
      Quote Originally Posted by chuckd71 View Post
      Chuck, its based on basic aerodynamics. The car generates both lift and downforce based on how the air flows above, around, and below the car. The faster you go the more air is going to go under the car generating lift. This is why when you look at modern performance cars, and race cars they are very low to the ground and have air dams to block air going under the car to stop the lift. There are also high and low pressure areas on the car, which are attempted to be controlled by vents, and ground effects as well.
      Every muscle car, not just Chevelle has front end lift, its based on the design of our cars. Think about a box moving through the air. If you lower your car you create a lower center of gravity, and reduce the amount of air flowing under the car. An air dam is the next step to continue reducing/controlling this air flow.
      To go even further you would want to have ducts, vents, a splitter, etc to increase the aerodynamics of the car.
      You also have to remember that even though the air is a gas, as you drive through it it acts like a solid. The faster you move the denser it gets. I remember reading/learning in a physics class something like at 70mph its like trying to drive through fog, 120mph its like driving through whip cream, 170mph its like angel food cake, and 200mph+ like a Christmas fruitcake.
      Yes, at lower speeds its not really that noticeable in normal driving situations, but what you will find is that the front end will feel light. What you mentioned about wheelies not getting landed isn't 100% true or false. Look at what happens to a lot of drag cars when they do not have wheelie bars. Or an even better example is the 1st & 2nd gen beetles which will flip over due to a high pressure buildup under the car at certain speeds.
      If you read through the post, there was something else at off with the alignment that made the car twitchy besides the common lift. I intend on going further to reduce the lift, hence the air dam.
      Ron Sutton started a thread on aerodynamics for muscle cars under the Advance Tech section that was a huge help in understanding how to increase aerodynamics of our cars for racing. In fact through my conversations with him, he helped in the design of my air dam, and its location in my car.
    10. #30
      Mar 2012
      New Jersey
      I hope my comment didn't come across as me being rude or a d**k. I was trying to be a honest and factual as I could about the cause of the list, and as much about the aerodynamics involved in for the given situation.
